Horizontal Stack Card Width on Panel
Hi All,
I was just wondering if its possible to set the width on Horizontal Stack cards when used in Panel Mode? - effectively, using 3 cards, I would like the 2 most outer cards to be left-aligned and right-aligned at a certain width with the middle card automatically taking up the remaining space in the middle - where-as at the moment, if I create a set of 3 horizontal stack cards they are all the same width.
I’ve tried also using the custom card-mod but I can’t see a way to do it there either.
Sorry if this has been asked before.
Leacho
Yeah, not card-mod, Thomas has another custom “card” for that which works best in panel mode:
Thanks @tom_l
Thanks for the awesomely quick reply!
I’ve now worked it out with Grid Column view using the link you sent.
Thanks Again
Leacho
