I’m trying to use horizontal stack with mushroom card. I’m setting this up according to a video that I have seen (no coding). The only thing that happens and I can’t figure out is that the card are being displayed in a strange way (see screenshot).
Why don’t they are being displayed below the other cards?
I have updated the my home assistant to the latest version.
Thank you
Can you post your code using the community standards? It will help expedite a solution.
Below the code that was used for this dashboard.
Regards,
sasa
- title: Home
cards:
- type: custom:mushroom-chips-card
chips:
- type: menu
- type: weather
entity: weather.knmi_thuis
show_conditions: true
show_temperature: true
- type: light
entity: light.slaapkamer_zolder_trap
- type: back
- type: custom:mushroom-title-card
title: ''
subtitle: |-
{% set time = now().hour %}
{% if (time >= 18) %}
Good Evening, {{user}}!
{% elif (time >= 12) %}
Good Afternoon, {{user}}!
{% elif (time >= 5) %}
Good Morning, {{user}}!
{% else %}
Hello, {{user}}!
{% endif %}
title_tap_action:
action: none
subtitle_tap_action:
action: none
- type: horizontal-stack
cards:
primary: house
secondary: ''
icon: mdi:home-plus-outline
icon_color: blue
layout: vertical
tap_action:
action: navigate
navigation_path: house
primary: Lights
secondary: ''
icon: mdi:lightbulb
icon_color: yellow
layout: vertical
tap_action:
action: navigate
navigation_path: lights
hold_action:
action: none
double_tap_action:
action: none
primary: Control
secondary: ''
icon: mdi:camera-control
layout: vertical
tap_action:
action: navigate
navigation_path: control
icon_color: purple
title: ''
title_tap_action:
action: none
action: none
subtitle: Rooms
cards:
- type: custom:mushroom-light-card
layout: vertical
icon_color: primary
entity: light.3_zolder_slaapkamer
layout: vertical
layout: vertical
subview: true
When you use this you are at the dashboard level
- title: Home
This is the card code.
type: custom:stack-in-card
cards:
chips:
- type: menu
- type: weather
- type: light
- type: back
title: ''
subtitle: |-
{% else %}
Hello, {{user}}!
{% endif %}
title_tap_action:
action: none
action: none
title: ''
title_tap_action:
action: none
action: none
subtitle: Rooms
cards:
primary: house
secondary: ''
icon_color: blue
layout: vertical
tap_action:
action: navigate
primary: Lights
secondary: ''
icon: mdi:lightbulb
icon_color: yellow
layout: vertical
tap_action:
action: navigate
hold_action:
action: none
double_tap_action:
action: none
primary: Control
secondary: ''
layout: vertical
tap_action:
action: navigate
icon_color: purple
cards:
layout: vertical
icon_color: primary
layout: vertical
layout: vertical
than you this worked.
