Hi all, spent 30 mins getting to where I’m at and 4 hours not being able to work out how to set the right most card (3rd in the horizontal stack - entities) to minimise/explicitly set the width of the innercard. I’ve tried card_mod and layout_card with neither being successful. Any guidance would be very appreciated.
type: custom:mod-card
style: |
ha-card {
border: 2px solid grey;
height: 186px !important;
hui-horizontal-stack-card:
#root > button-card {
margin: 0;
card:
type: horizontal-stack
cards:
- type: custom:button-card
styles:
card:
- height: 180px
- width: 190px
- border-radius: 20px
- font-size: 25px
- padding-bottom: 30px
- padding-top: 0px
- padding-right: 0px
entity: input_boolean.theatre_room_target_temperature
icon: mdi:theater
show_icon: true
tap_action:
action: toggle
- type: vertical-stack
cards:
- type: custom:numberbox-card
border: true
entity: input_number.theatre_room_min_target_temperature
card_mod:
style: >
ha-card {
height: 85px !important;
padding-top: 15px !important;
} ha-card .cur-num { font-size: 20px;
color: red
} ha-card .cur-num { font-size: 25px; }
.body{display:block!important}
.body::after{text-align:center;font-size:15px;content:"Min
Temp";display:block!important}
border: true
entity: input_number.theatre_room_max_target_temperature
card_mod:
style: >
ha-card {
font-size: 20px;
color: blue
font-size: 25px;
} .body{display:block!important}
.body::after{text-align:center;font-size:15px;content:"Max
- entities:
- entity: sensor.theatre_room_temperature
direction: up
height: 60px
width: 20px
min: 0
max: 40
stack: horizontal
type: custom:bar-card
positions:
icon: 'off'
value: inside
card_mod:
style: >
ha-card .value-direction-up {
font-size: 14px;
color: white;
writing-mode: vertical-rl;
text-orentation: upright;
margin-bottom: 70px
font-size: 25px;
Layout card allows you to define the column widths when using the grid layout
type: custom:layout-card
layout_type: custom:grid-layout
layout:
grid-template-columns: 1fr 1fr 1fr
margin: 0px 0px 0px 0px
cards:
grid-template-columns: 1fr 1fr 1fr will also accept percentages.
grid-template-columns: 30% 30% 40%
You most likely do not need to use the card-mod card
I swapped some card types. I don’t have custom:numberbox-card
layout:
cards:
styles:
card:
- height: 100%
- font-size: 15px
- padding-top: 0px
entity: input_boolean.test
icon: mdi:theater
show_icon: true
tap_action:
action: toggle
cards:
border: true
entity: input_number.test3
border: true
- entities:
- entity: sensor.basement_sensor
direction: up
height: 60px
width: 20px
min: 0
max: 40
stack: horizontal
positions:
icon: 'off'
value: inside
Thanks; the reason I’m using card-mod was to do the border as there will be other “groups” on the page so I use this to differentiate between them. I have tried with the grid but cannot get it to work (perhaps it’s a conflict with card-mod)?
On another note - I see that there’s percentages and this is probably another thing I’m confused about/run into issues. I’m looking to set a static pixel width rather than a percentage width. Do you know if this is possible?
Adding the card-mod card does not conflict
card_mod:
style: |
ha-card {
card:
layout:
cards:
styles:
card:
- height: 100%
- font-size: 15px
- padding-top: 0px
icon: mdi:theater
show_icon: true
tap_action:
action: toggle
cards:
border: true
border: true
- entities:
direction: up
height: 60px
width: 20px
min: 0
max: 40
stack: horizontal
positions:
icon: 'off'
value: inside
Oh excellent thanks so much I’m almost there! I think I had the grid placed in the wrong area
The last thing is removing the padding (top/bottom/left/right) that seemingly the right most temperature has. I looked in element inspector and can’t for the life of me see any references to override.
card_mod:
style: |
ha-card {
card:
layout:
grid-template-columns: 200px auto 30px
cards:
styles:
card:
- height: 100%
- font-size: 25px
- padding-top: 0px
icon: mdi:theater
show_icon: true
tap_action:
action: toggle
cards:
border: true
card_mod:
style: >
ha-card {
color: red
border: true
card_mod:
style: >
ha-card {
font-size: 20px;
color: blue
font-size: 25px;
- entities:
direction: up
height: 90px
width: 20px
min: 0
max: 40
stack: horizontal
positions:
icon: 'off'
value: inside
card_mod:
style: |
font-size: 14px;
color: white;
margin-bottom: 70px
font-size: 25px;
card_mod:
style: |
.card-content {
margin-left: -16px;
font-size: 14px;
color: white;
margin-bottom: 70px;
.cur-num {
font-size: 25px;
Adjusted it a bit, but it should get you going in the right direction.
Brilliant, thank you so much really appreciate it have been going crazy trying to get it all to work together.
Happy to assist!
As a quick note for future use. If you have ha-card as a pre-fix, you can generally remove it. You can always test it removing it with little to no harm.
ha-card .cur-num { font-size: 25px; } will work as .cur-num { font-size: 25px;}
