Host Log: bcmgenet reporting link is up/down constantly?
I’m seeing a constant stream of these errors in the HA Host log:
[173578.512789] bcmgenet fd580000.ethernet eth0: Link is Down
[173581.580878] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[173583.628878] bcmgenet fd580000.ethernet eth0: Link is Down
[173587.724930] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[173588.748897] bcmgenet fd580000.ethernet eth0: Link is Down
[173592.845044] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[173593.869108] bcmgenet fd580000.ethernet eth0: Link is Down
[173597.965242] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[173598.989076] bcmgenet fd580000.ethernet eth0: Link is Down
[173603.085159] bcmgenet fd580000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[173637.901600] bcmgenet fd580000.ethernet eth0: Link is Down
[173641.997714] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Is this normal?
I’ve changed the ethernet cable between the RPi4 and the switch to no effect…
System Health
version core-2021.3.4
installation_type Home Assistant OS
dev false
hassio true
docker true
virtualenv false
python_version 3.8.7
os_name Linux
os_version 5.4.83-v8
arch aarch64
timezone Europe/Amsterdam
Home Assistant Community Store
GitHub API ok
Github API Calls Remaining 4853
Installed Version 1.11.3
Stage running
Available Repositories 841
Installed Repositories 11
Home Assistant Cloud
logged_in true
subscription_expiration 19 April 2021, 2:00
relayer_connected true
remote_enabled false
remote_connected false
alexa_enabled true
google_enabled true
can_reach_cert_server ok
can_reach_cloud_auth ok
can_reach_cloud ok
Home Assistant Supervisor
host_os Home Assistant OS 5.12
update_channel stable
supervisor_version supervisor-2021.03.6
docker_version 19.03.13
disk_total 109.3 GB
disk_used 9.1 GB
healthy true
supported true
board rpi4-64
supervisor_api ok
version_api ok
installed_addons File editor (5.2.0), Samba share (9.3.1), InfluxDB (4.0.3), Terminal & SSH (9.1.0), Grafana (6.2.0), Z-Wave JS (0.1.16), Z-Wave JS to MQTT (0.9.1)
Lovelace
dashboards 2
resources 8
views 4
mode storage
Update:
I moved the ethernet cable to another port on the switch and there was no change to the issue.
If I look at the status LEDs on the RPi4’s ethernet port I see that both go out every few seconds - this means that the ethernet port is briefly not working?
Is this a hardware issue on the RPi4?
2nd Update:
I’ve swapped out the 2GB RPi4 and its power supply adaptor for another set, and connected the USB SSD holding the HA software to this replacement.
After an hour running, I’ve seen no instance of the ethernet port going down in the Host log, so I conclude this has been either a hardware issue with the RPi4 or an under-spec power supply adaptor.
Case closed?
