what to make of this, cant get the host to reboot anymore…
core-ssh:~# hassio host reboot
ERROR
panic: interface conversion: interface is nil, not string
goroutine 1 [running]:
panic(0x2c7050, 0x1076b720)
/home/travis/.gimme/versions/go1.7.6.linux.amd64/src/runtime/panic.go:500 +0x33c
github.com/home-assistant/hassio-cli/command/helpers.DisplayOutput(0x107b8200, 0x24, 0x200, 0x0)
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/helpers/common.go:118 +0x3c8
github.com/home-assistant/hassio-cli/command/helpers.ExecCommand(0x2f45fc, 0x4, 0x7eb88e5a, 0x6, 0x0, 0x0, 0x76500, 0x0, 0x0, 0x0, ...)
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/helpers/common.go:155 +0x308
github.com/home-assistant/hassio-cli/command.CmdHost(0x10786420)
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/host.go:42 +0x4f0
github.com/urfave/cli.HandleAction(0x2af768, 0x324b18, 0x10786420, 0x0, 0x0)
/home/travis/gopath/src/github.com/urfave/cli/app.go:503 +0xf0
github.com/urfave/cli.Command.Run(0x2f45fc, 0x4, 0x0, 0x0, 0x40bd20, 0x1, 0x1, 0x2fabdf, 0x18, 0x0, ...)
/home/travis/gopath/src/github.com/urfave/cli/command.go:165 +0x6b8
github.com/urfave/cli.(*App).Run(0x107708c0, 0x1076a080, 0x3, 0x4, 0x0, 0x0)
/home/travis/gopath/src/github.com/urfave/cli/app.go:259 +0x8b0
main.main()
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/main.go:22 +0x108
core-ssh:~#
