Hostname in my DHCP server is not updated
I trying to understand why the hostname of my ESPHome device is not updated in my routers DHCP list. Yes I have a simple TP-Link Router…
The hostname shown in the DHCP server is test-tuya (a name I created a while ago). I have rebooted the router and rebooted the ESPHome device.
I can adress the device using the name defined in the config file (biltema1.local) but why isn’t it reflected in the router.
My ESP config file looks like below:
esphome:
  friendly_name: biltema1_friendly
  name_add_mac_suffix: False
bk72xx:
  board: generic-bk7231t-qfn32-tuya
logger:
web_server:
captive_portal:
mdns:
api:
  password: ""
ota:
  password: ""
wifi:
  #manual_ip:
    # Set this to the IP of the ESP
    #static_ip: 192.168.0.147
    # Set this to the IP address of the router. Often ends with .1
    #gateway: 192.168.0.1
    # The subnet of the network. 255.255.255.0 works for most home networks.
    #subnet: 255.255.255.0
  #use_address: biltema1.local
  ssid: !secret wifi_ssid
  ap:
button:
  - platform: restart
biltema.local is a mdns address
Yes but shouldn’t my DHCP server pick up the new hostname
I suspect there is some caching going on - associating the original hostname with the mac address.
What dhcp server?
TP-Link Archer AX50 v1.0
I also reduced lease-time to 1 minuted but same result
Yes but what dhcp software does it have?
No clue what TP link are using for this specific model
Any option in the TP Link to delete clients from the DHCP-List and/or DHCP reservations? The router might remember the device using the MAC
Haven’t found anything like that. I have done a SW reboot and a HW reboot. DHCP request looks ok.
Probably this is a just another fault in the Router FW that I need to live with
  TIME: 2023-11-04 13:51:30.658
    IP: 0.0.0.0 (fc:67:1f:fc:93:c3) > 255.255.255.255 (ff:ff:ff:ff:ff:ff)
    OP: 1 (BOOTPREQUEST)
 HTYPE: 1 (Ethernet)
  HLEN: 6
  HOPS: 0
   XID: 6954af37
  SECS: 0
 FLAGS: 0
CIADDR: 0.0.0.0
YIADDR: 0.0.0.0
SIADDR: 0.0.0.0
GIADDR: 0.0.0.0
CHADDR: fc:67:1f:fc:93:c3:00:00:00:00:00:00:00:00:00:00
 SNAME: .
 FNAME: .
OPTION:  53 (  1) DHCP message type         3 (DHCPREQUEST)
OPTION:  57 (  2) Maximum DHCP message size 1500
OPTION:  50 (  4) Request IP address        192.168.0.147
OPTION:  54 (  4) Server identifier         192.168.0.1
OPTION:  55 (  4) Parameter Request List      1 (Subnet mask)
					      3 (Routers)
					     28 (Broadcast address)
					      6 (DNS server)
OPTION:  12 (  8) Host name                 biltema1
I found out what the problem is. TP-Link has in their Routes implemented this having a possibility to define a Device Name. If no Device name is specified it uses the device host name. But once defining a device name it’s not possible to revert back. I have reported this to TP-Link and they will bring it up with the engineering team
