I have just moved my smart home devices from Domoticz to Home Assistant and want to automate my hot water boilers further. Currently I use basic automation to turn them on at 23:00h and turn them off at 6:00 so I can take advantage of the off peak electricity tariff.
The question:
Is there a way to tell home assistant that I am going on a holiday for example from 1st of September to 10th of September so home assistant can disable the boiler automation on the 1st and enable it on the 9th(one day before I come back since the boilers work at night, so I can have hot water on the 10th). I guess I can figure out something in the config files but I was wondering If I can make it through the web interface from some sort of date picker or calendar card or just add an all-day event in my google calendar from 1st to 10th of September and integrate the calendar with home assistant. Have any of you did something similar?
