Googled and tried a lot but still confused
Someone out there running HA and a mqtt broker - i.e. mosquitto - in a docker environment on a Raspi (Raspbian) and is willing so share the mosquitto install/setup?
I don’t currently run the Mosquitto MQTT Broker as a docker container. However, I plan to do so in the future. To prepare for it, I collected configuration examples from people who were using docker-compose to start their mosquitto container.
Here are the four samples I’ve collected. Perhaps they can give you some insight into how you wish to configure your system.
# Sample 1
mqtt:
container_name: MQTT
restart: unless-stopped
image: eclipse-mosquitto
volumes:
- /srv/docker/mosquitto/config/mosquitto.conf:/mosquitto/config/mosquitto.conf
- /srv/docker/mosquitto/log:/mosquitto/log
- /srv/docker/mosquitto/data:/mosquitto/data
- /etc/localtime:/etc/localtime:ro
ports:
- "1883:1883"
- "9001:9001"
# Sample 2
mosquitto:
container_name: mosquitto
ports:
- "1883:1883"
volumes:
- /opt/docker/mosquitto:/mosquitto/config:ro
- /opt/docker/mosquitto:/mosquitto/data
restart: on-failure
# Sample 3
mosquitto:
user: "1000:1000"
ports:
- 1883:1883
volumes:
- /opt/mosquitto:/mosquitto/config:ro
- /opt/mosquitto:/mosquitto/data
restart: on-failure
# Sample 4
mqtt:
image: eclipse-mosquitto:latest
container_name: "MQTT"
restart: always
ports:
- 1883:1883
- 9001:9001
volumes:
- /home/$USER/docker_files/mqtt/data:/mosquitto/data
- /home/$USER/docker_files/mqtt/config:/mosquitto/config
- /home/$USER/docker_files/mqtt/log:/mosquitto/log
network_mode: "host"
environment:
- TZ=America/New_York
Thanks for that
I got the container running with a command similar to Sample 4, but to see the outputs with a discrete docker run.
docker run -itd -p 1883:1883 -p 9001:9001 -v /home/mosquitto/mosquitto.conf:/mosquitto/config/mosquitto.conf -v mosquitto_data:/mosquitto/data -v mosquitto_data:/mosquitto/log --name mosquitto eclipse-mosquitto
But now, how to successively check, if it is working and connect to HA? There are a lot of steps which might fail and I would like to check step by step…
(Had used the HA-internal mqtt-broker before…)
I used
mosquitto_pub -V mqttv311 -u test -P test -t "some_mqtt/topic/here" -m "Meine erste MQTT-Message"
which answers nothing. When I stop the container I get
Error: Connection refused
Looks like the broker is receiving the message…
You can use any client, I like MQTT-Explorer to verify you can connect and sub/pub on topics.
You don’t “connect to HA”, you have HA connect to it.
Did you set a user/pass in your broker? if you didn’t, why are you passing a user/pass to it?
Great hint! Could verify that my container is running and receives messages.
user/pass not yet set. Copy & paste the old test message which I have used for the internal broker.
Then it won’t connect trying to use a user/pass. try without those options to see if the broker is working.
Hhm, a bit more confused…
Firing the mosquitto_pub command from above (with -u and -P) I see the message in the MQTT-Explorer… Shouldn’t I?
But what to put in the HA configuration.yaml?
It can’t connect if you don’t have the server setup with a user/pass
If you don’t set the server up with a user/pass, you don’t need to add that
Sometimes its so easy…
Skipped the security and password to be solved later. Till now, my Raspi isn’t exposed to the internet and the MQTT-messages are just temperature values.
Just copied the old zigbee2mqtt sensor yaml to the new location and I see all my temperature values ![]()
For those who are trying the same. Here is my configuration:
Start the container manually:
docker run -it -d -p 1883:1883 -p 9001:9001 eclipse-mosquitto:latest
Use docker-compose:
version: '3'
services:
mqtt:
ports:
- "1883:1883"
- "9001:9001"
volumes:
- /home/pi/mosquitto/config:/mqtt/config:ro
- /home/pi/mosquitto/log:/mqtt/log
- /home/pi/mosquitto/data/:/mqtt/data
Default file (in my case) located in directory /home/pi/mosquitto/conf
# Place your local configuration in /mqtt/config/conf.d/
pid_file /var/run/mosquitto.pid
persistence true
persistence_location /mqtt/data/
user mosquitto
# Port to use for the default listener.
port 1883
log_dest file /mqtt/log/mosquitto.log
log_dest stdout
include_dir /mqtt/config
Curious if you figured out the setup a password part. Having issues with that in Docker, though honestly it’s not the biggest deal considering all the MQTT traffic is local.
