So I have a Lay z spa air jet pump and I have also purchased the hottubmanager add on to control it wirelessly.
It’s connected up fine and I can control the pump via their web page. The site says works with HA but just looking for anyone who has and can give some setup pointers.
Has anyone here integrated this in to home assistant yet?
yep i did have a fiddle for a while but once i got the right information into it it just appeared in the MQTT intergration
MQTT destination: is the just the ip address of your HA install ie 192.168.1.100
the MQTT username: & MQTT password: is not the one in Broker options but the one you use to access MQTT, sounds obvious but it took me a while to work that out
Home Assistant destination: is just the ip address of your HA install ie 192.168.1.100 not 192.168.1.100:8123
