Hotwater Boiler and LaserLED as status Light problem
i want an automation in ESPhome, but cant get it running.
I have:
an Hot water Boiler (Quoka / Grohe Red), with an Dallas Temperature Sensor inside
an Sonnoff TH16 ( 1 Relay, 1 Dallas sensor , 1 (Laser)LED on GPIO4 )
the LaserLED is directed to the floor, so i have a nice red dot on the floor.
I want:
the LaserLED should show the state of my hot water Boiler.
  1. if relay is off and temperature is low (lower than normal warm water <60 °) LaserLED off.
  2. if relay is on and the temperature is low (below 80 °C) the LaserLED should flash from off to on with transition (the blinking is no problem)
  3. if relay is on and the temperature is high (above 80.1 °C) the LaserLED should stay on (no flashing)
  4. if relay is off and the temperature is still high ( if no water is taken out, the temperature drops very slowly ) the LaserLED should flash from on to off with transition
Info: The boiler has its own temperature sensor, and security mechanism so that no overheating is possible.
here is my code:
# Device Description
#Pin    Function
#GPIO1  TX pin (C1 Pin 2)
#GPIO3  RX pin (C1 Pin 3)
# Folgende Werte Steuern die Schwellwerte für die LaserLED/Signal LED
substitutions:
  devicename: esphotwater
  human_devicename: Heisswasser  # Name in HA
  gpio_taster:    '0'     # GPIO0  Button (inverted)
  gpio_relay:     '12'    # GPIO12 Relay & RED LED
  gpio_blueled:   '13'    # GPIO13 Blue LED (inverted)
  gpio_dallas:    '4'     # GPIO4  Optional Sensor (C1 Pin 5)
  gpio_laserled:  '2'     # GPIO2  B59D10_laserled Optional Pin EXP-LOG (TH16 Ver 2.1 2019)
  Temperatur_on:  '91'   # Temperatur wenn LaserLED dauerhaft an sein soll - Temperatur voll erreicht
  Temperatur_off: '67'   # Unterhalb dieser Temperatur ist das Gerät aus (Nachts)
packages:
   wifi: !include common/wifi.yaml # Wifi SSID/Passwort
   misc: !include common/misc.yaml # Web Interface
   time: !include common/time.yaml # ZeitServer
   api:  !include common/api.yaml  # API Daten
logger:
  level: INFO
esphome:
  platform: ESP8266
  board: esp01_1m
text_sensor:
  - platform: wifi_info
    ip_address:
      name: $human_devicename Wifi IP
    mac_address:
      name: $human_devicename Wifi MAC
    ssid:
      name: $human_devicename Wifi SSID
  - platform: version
    name: $human_devicename ESP Version
    hide_timestamp: true
    icon: mdi:wrench
    icon: mdi:clock-start
dallas:
  - pin: $gpio_dallas
    update_interval: 10s
  - <<: !include common/sensor_wifisignal.yaml # <- WiFi Status
  - <<: !include common/sensor_uptime.yaml     # <- Human Uptime in D H M s
# Individual sensors - Dallas oder Anaolog NTC
  - platform: dallas
    address: 0xB301145DE7EA6F28
    name: "$human_devicename Temperatur"
    filters:
      - filter_out: nan
      - offset: +17
    # works with dallas
    on_value:
      then:
        - if: # state off
            condition:
              lambda: |-
                if (x < $Temperatur_off){
                return true;
                } else {
                return false;
            then:
              - logger.log: "State 1 below $Temperatur_off"
              - switch.turn_off: laser_on
              - switch.turn_off: laser_heat
              - switch.turn_off: laser_cool
              - light.turn_off: laserled_light
              - text_sensor.template.publish:
                  state: "Off"
            else: # state warm
              - logger.log: "State 2 above $Temperatur_off"
              - if: # check temperature
                  condition:
                    lambda: |-
                      if ( (x > $Temperatur_off) or (x < $Temperatur_on) ){
                      return true;
                      } else {
                      return false;
                  then:
                    - logger.log: "State 3 above $Temperatur_off or under $Temperatur_on State"
                    - if: # check if relay is on
                        condition:
                          lambda: 'return id(relay).state;' # is inverted
                        then:
                          - logger.log: "State 4 Range above $Temperatur_off and relay on"
                          # turn off all other
                          - switch.turn_on: laser_heat
                              state: "Heat"
                          - if: # check if tempreture is high
                              condition:
                                lambda: |-
                                  if (x > $Temperatur_on){
                                  return true;
                                  } else {
                                  return false;
                              then:
                                - logger.log: "State 5 Range above $Temperatur_on relay on"
                                - switch.turn_on: laser_on
                                    state: "Ready"
                              else:
                                - logger.log: "State 6 Range above $Temperatur_on error 1"
                                    state: "Error 1"
                        else:
                          - logger.log: "State 5 Range above $Temperatur_off and relay off"
                          - switch.turn_on: laser_cool
                              state: "Cool"
                              condition:
                                lambda: |-
                                  return true;
                                  } else {
                                  return false;
                              then:
                                - logger.log: "State 7 Range above $Temperatur_on relay off"
                                    state: "Ready but off"
                              else:
                                - logger.log: "State 8 Range above $Temperatur_on error 2"
                                    state: "Error 2"
binary_sensor:
  - <<: !include common/binary_sensor.yaml # <- HA connection status
  # Sonnoff Taster
  - platform: gpio
    pin:
      number: $gpio_taster
      mode:
        input: true
        pullup: true
      inverted: true
    on_press:
      - switch.toggle: relay
      - switch.toggle: blue_led
switch:
  - <<: !include common/switch.yaml # Reset Button on webui
  # Relay boiler on/off
  - platform: gpio
    pin: $gpio_relay
    inverted: false
  - platform: gpio
    pin: $gpio_blueled
    inverted: false
    internal: true
  # LaserLED Dauerpermanent on
    optimistic: true
  #  internal: true
    turn_on_action:
      then:
      - light.turn_on:
    turn_off_action:
      then:
      - light.turn_off:
          transition_length: 100ms
  # LaserLED flash dunkel -> hell
    name: "$human_devicename aufheizen"
    optimistic: true
  #  internal: true
    turn_on_action:
    - while:
        condition:
           lambda: 'return true;'
        then:
        - light.turn_on:
            transition_length: 3s
        - delay: 3500ms
        - light.turn_off:
            transition_length: 1ms
        - delay: 700ms
    turn_off_action:
      then:
      - light.turn_off:
  # LaserLED flash hell -> dunkel
    name: "$human_devicename abkühlen"
    optimistic: true
   # internal: true
    turn_on_action:
    - while:
        condition:
        then:
          - light.turn_on:
          - delay: 700ms
          - light.turn_off:
          - delay: 3500ms
    turn_off_action:
      then:
      - light.turn_off:
output:
  # Register the LED as a dimmable output ....
  - platform: esp8266_pwm
    pin: $gpio_laserled
    inverted: false
light:
  # ... and then make a light out of it.
  # LaserLED dot on the flor
  - platform: monochromatic
    name: "$human_devicename LaserLED Light"
    output: laserled
    internal: true
I have updated the code. and its nearly working now. ( i forgot to implement an Version counter, but ist must be version 123 if not more :slight_smile: )
But there are two Problems:
  1. The status is “flickering” if process go’s down the lines status get set off,heat,ready
  2. If the temperature is below off and i turn on the relay, the LaserLED stay off, (id false the device is in but it needs more time of course)
You have code and a description of the desired operation, but no problem or question described.
I have updated the code and described my two problems with that code.
MfG TiBo
There is an other Problem
3: the blinking light gets overwriteen so itis half of both blinking sequences. I thing tats an Timeing Problem
