Thanks @picomatic i found that; just still not seeing the module / entity / integration in my overview, i just get a brief empty popup after adding and then it’s gone. Could you please check if i’m doing the right thing in the screen capture here: https://www.loom.com/share/6a7af5b9924346f6bfbe95ef87db65d7
You are doing fine, the problem at the moment is that there is no gas data, which ensures that the entities do not work for existing users and if you want to add the integration, it will not load further.
Thanks. Probably create sort of a fallback to another gas data supplier; or set the value to 0.00 if there is no data available?
In the meanwhile i started up another HA instance on my raspberry pi and that seems to be a bit more rigid, with also the possibility for add-ons etc, also bluetooth etc. I think that’s the way to go for me.
Just to be sure: the prizes do not contain the ANWB inkoopkosten, taxes, vat?
If not: is there a way to configure an entity that contains the extra costs so the numbers presented are real prizes? (or just configure a number)
Only VAT is included, you should indeed add the rest yourself. This could be done, for example, by making a template sensor, I think there are some examples of this in this topic.
Right now the numbers that it produces do not mean anything to me if it doesn’t show real numbers. Therefore it would be great if the plugin gets a way to add taxes:
two configurable numbers in the integration config that is added to every kWh/m3 or
Good addition, I had some ideas about that before.
However, it is not really the intention that an integration will adjust this internally, unless the API returns all the taxes on its own. As a result, you will eventually have to make some template sensors, we can think of something to make this as simple and less lines of code
I think i’ve got it working now. A bit off topic: Now i’m trying to see if my car will charge while the energy price is below 17 cents. Do you reckon this would work? Any advice for a HA noob?
I have not seen it before, but the information about entso-e is known to me.
The main difference is that the integration for energyzero is made specifically for their API, in terms of entities you get the same as with ENTSO-e. However, the piece of visualization for the apexchart will be missing in core (but you can still add it as a custom component)
For me also a little bit off topic. But I have a tesla integration and there is a sensor to see the added energy. How can I make a counter to see the price for a total charge?
Because the counter for added energy increases over the hours, but when you have a dynamic price you can’t multiply the total charged x price because it will only uses the latest price then.
So how to create an hourly calculation and then a total calculation?
