House whith house zone not displayed on map
i don’t know how since i have this issue but i can’t see my house on map.
The latutude and logitude are configured from first installation and in the past the map works fine.
homeassitant release 0.87.0 on raspbian (no hassio)
no errors reported in the logs
below the section of configuration.yaml file:
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: 41.458907
longitude: 12.433729
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 50
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Rome
# Customization file
# Enables a map showing the location of tracked devices
map:
This is the map whitout the house
Use the “</>” and repost code
code reposted
Try repost again
Select the text that is code then select “</>”
It should have same space and I dents as your code
i resolved this issue,
I had to reenable the device_traker:
