I’m using the template sensor to monitor my daily running total energy usage of Gas & Electricity and energy generation from my solar system which works brilliantly and accurately MOST of the time. The only time a error occurs is if I do a restart of HA then sometimes not always the figure will jump. I’m certain the restart is the issue, so is there any way I can add a configuration to stop this happening
The running total of my Electricity Usage this morning (the flat horizontal line) was 2.4kWh until I restated HA (after changing a configuration value in my Config.yaml for something else) then after the restart it jumps to 264,000 kWh
Can you provide more info on how the template sensor is calculated/created ?
utility_meter:
electricity_daily:
source: sensor.currentcost_electric_meter
cycle: daily
offset: 0
sensor 10:
sensors:
daily_electricity:
unit_of_measurement: kWh
value_template: "{{ (states('sensor.electricity_daily')| float) | round (1) }}"
friendly_name: Daily Electricity
