In the next lines I show you how to connect your HA to the ‘slimme meter’ with a small piece of hardware and small extra configuration ‘under’ HA.
First of all you need to make the next hardware:
Second we have to change a few params in the next files:
/etc/config.txt
# Activate UART for 'slimme meter'
dtoverlay=pi3-disable-bt
enable_uart=1
/etc/cmdline.txt
# remove any console command like;
console=ttyAMA0,115200
console= xx
/etc/suoers.d
# Give the user homeassistant enough (hw) rights
in bottom of file;
pi ALL=(ALL) NOPASSWD: ALL
homeassistant ALL=(ALL) NOPASSWD: ALL
As last to do; make the homeassisant user member of the dialout group
sudo usermod -a -G dialout homeassistant
REBOOT the Raspberry Pi
Check in the shell if you can see the telegram data from the ‘slimme meter’ with the next command:
cu -l /dev/ttyAMA0 -s 115200 --parity=none -E q
If you see the next strings after a few seconds … then you hardware is talking to you in the Rpi.
Connected.
/Ene5\XS210 ESMR 5.0
1-3:0.2.8(50)
0-0:1.0.0(171105201324W)
0-0:96.1.1(4530303437303030303037363330383137)
1-0:1.8.1(000051.775*kWh)
1-0:1.8.2(000000.000*kWh)
1-0:2.8.1(000024.413*kWh)
1-0:2.8.2(000000.000*kWh)
0-0:96.14.0(0001)
1-0:1.7. etc. etc.
The last steps with the configuration issues in HA
You can place all the commands in the configurations.yaml or in the dependent files sensors.yaml and groups.yaml
sensors.yaml
- platform: dsmr
port: /dev/ttyAMA0
dsmr_version: 4 # Check your hardware type of 'slimme meter'
groups.yaml
group:
meter_readings:
entities:
- sensor.power_consumption_low
- sensor.power_consumption_normal
- sensor.power_production_low
- sensor.power_production_normal
- sensor.gas_consumption
Used links:
http://domoticx.com/p1-poort-slimme-meter-hardware/
https://willem.aandewiel.nl/index.php/2019/02/11/home-assistant-integratie-met-de-dsmr-logger/
http://gejanssen.com/howto/Slimme-meter-uitlezen
