How add Tariff from UI of Utility Meter
I can’t add tariff in the UI of Utility Meter.
Could you help me ?
How populate the drop down list ? ?
KG
Could this be the problem you are having? Cannot enter tariffs in utility meter · Issue #14703 · home-assistant/frontend · GitHub
Are you running a version of HA that is from 08 November 2022 or later?
Update frontend to 20221201.1 (#83062) FAIL
Update frontend to 20221130.0 (#83014) FAIL
Update frontend to 20221108.0 (#81787) WORKS
Yes, you right, new hacs so last version.
I follow git ticket, this case can be close
Looks like a fix for adding multiple tariffs to Utility Meter through the UI has been proposed. Hopefully it will be released soon. Allow custom value for multiple select by piitaya · Pull Request #14839 · home-assistant/frontend · GitHub
