ashscott
(Ash)
1
The value template works fine in dev tools but I cant get past the config check.
sensors:
sensor name:
friendly_name: "Circulation time"
value_template:
"{{% set hours = (11526 / states('sensor.total_circulation_lph') | int) | float %}
{% set minutes = ((hours % 1) * 60) | int %}
{% set hours = (hours - (hours % 1)) | int %}
{{ '%02i:%02i'%(hours, minutes) }}"
I should add that this is my first value template! (and not all mine at that).
mk-maddin
(Martin)
2
You cannot do “{{%”
try:
sensors:
sensor name:
value_template: >-
ashscott
(Ash)
3
Thanks for the help.
I’m still getting:
Invalid config for [sensor.template]: invalid slug sensor name (try sensor_name) for dictionary value @ data['sensors']. Got OrderedDict([('sensor name', OrderedDict([('friendly_name', 'Circulation time'), ('value_template', "{% set hours = (11526 / states('sensor.total_circulation_lph') | int) | float %} {% set minutes = ((hours % 1) * 60) | int %} {% set hours = (hours - (hours % 1)) | int %} {{ '%02i:%02i'%(hours, minutes) }}")]))]). (See ?, line ?).
petro
(Petro)
4
when you see references to slug
it means the field that your template resides in.
You can’t have spaces or capitals in your slug. change that to circulation_time
or something simliar.
EDIT: Also, that template does not protect against dividing by zero… If sensor.total_circulation_lph
is ever zero, you’ll get errors.
sensors:
circulation_time:
value_template: >-
{% set lph = states('sensor.total_circulation_lph') | int(none) %}
{% if lph %}
{% set hours = 11526 / lph %}
{% else %}
none
{% endif %}
ashscott
(Ash)
5
Brilliant!
Works a treat. Thank you for taking the time.
