Thank you, I did several searches yesterday and didnt see that page. It is very helpful. IMO if they implemented a prioritization ranking (number) to each device it would simplify the decision matrix (use and understanding) and make it more robust. I’ll put in a feature request.
Still would love to see how people do there occupancy detection automations… I suspect I using Node Red may be better for these complex automation… so I now need to learn NR
As long as you have 1 or 2 reliable device trackers, it’s should be rare for you to need to use automations to detect occupancy, let alone use NR for it.
FWIW, from my experience when I was a new user, you will be better off if you just commit to either learning HA automations or NR… bouncing back and forth will just slow your progress in both. If you choose NR you may want to join the Home Assistant subreddit. Not to say that it’s unwelcome here on the forums, but there tends to be more NR content there.
I used to use my router integration (Unifi) for home/away detection but have since moved to GPS location via the companion app.
The router updates were just too infrequent to detect especially the away state properly; I could be quite a distance away from the house before the Unifi integration reported me to be away and armed the alarm.
It also allows me to move from my standard WLAN onto another one (e.g. the IOT one for testing, but I also have one with a full ad blocker/VPN) without having the lights turned off on me all over the house
As an extension to the home/away I set up a template sensor, so when the phone is home, instead of just showing me as being ‘home’ it uses Bermuda to show me which room the phone is in.
So when I’m away, it shows which zone I’m in (if any, otherwise it just says ‘Away’) and when I’m home it shows the room (e.g. ‘Office’) or just ‘Home’ when I’m inside the Home Zone but outside ot BLE reach.
