I estabilished the zone around the location of my server, then I enabled “location zone” in the Android app, which is supposed to download the zones and only update the server about zone entering/exiting.
So far it seems to work fine, although I never specified that the location of the server would also be “home”, and I still get “home” and “not_home” states. But this is just a minor annoyance.
After this, I defined a different zone on the server. My problem is that I don’t get any state updates when I enter/leave this second zone.
At this point, I’m wondering if the app simply didn’t update its list of zones (in this case, when does it update?), or I’m completely misunderstanding how this is supposed to work.
the first zone you create is the Home Zone so you will indeed get home and not home status immediately
The list is updated upon app startup, so if you added more zones and teh app was currently running you’ll want to restart the app so it can pick up those changes.
Also, how do I set the radius of the zone around the server’s location? It’s read-only on the UI, and I couldn’t find in the config files where I could modify it.
