hello i want get these values
from this website: http://www.transporlis.pt/DesktopModules/trp_horarios/Ajax/trp_horario_2.ashx?cmd=getLine&codOp=2&lineId=164&hora=23&min=33&date=25-9-2018
i am trying use :
- platform: scrape
resource: https://www.home-assistant.io
select: "_______"
- platform: scrape
select: "_______"
but i dont know what i should put on SELECT:
@Mariusthvdb , @Bob_NL any ideas?
lolouk44
(lolouk44)
2
Assuming they’re ALWAYS going to be in the same place, you’d need a count of <p>
or a count of <td
- platform: scrape
resource: http://www.transporlis.pt/DesktopModules/trp_horarios/Ajax/trp_horario_2.ashx?cmd=getLine&codOp=2&lineId=164&hora=23&min=33&date=25-9-2018
select: 'p:nth-of-type(8)'
- platform: scrape
select: 'p:nth-of-type(12)'
You may need to adjust the numbers (8 and 12) if the position is a bit different
finity
3
I’m not sure if you can use this or not but I needed to create a sensor to get the state of motion detection on my cameras.
I ended up using a command line sensor and used ‘curl’ to get the website info and ‘grep’ to split out what info I wanted from it.
Here is the command line portion:
command: 'curl -k --silent "http://192.168.1.52:8002/cgi-bin/CGIProxy.fcgi?cmd=getDevState&usr=xxxx&pwd=yyyy" | grep -oP "(?<=motionDetectAlarm>).*?(?=</motionDetectAlarm>)"'
You could create a sensor for each city using the same website address but change the grep parameters to only read the info between (for example)
"saldanha</a></p></td><td class="description" valign="top"><p>"
and the next
"</p>"
That way it doesn’t matter where it is it just matches on a search string and returns the result of whatever is between them.
