I have a hassbian installation which is a couple of months old.
While browsing for the commands to update my home assistant version I found a not on the “updating hassbian” page that there is now a new way to update home assistant. It says that:
you can also use hassbian-config to automate the process by running sudo hassbian-config upgrade home-assistant
However, my hassbian-config command does not know the upgrade command.
