How can I access the components folder in hass.io?
in hassbian,there is a folder named “components”, and I can install some non official components by adding the them into components folder.
But in hass.io, i can’t find the conponents folders. Is there a way to intall a third party components in hass.io
First of all install one of the ssh add-ons in the Hassio panel.
Then configure that and login and you can then simply navigate to the config directory and the custom_components directory will be there (or you can create it)
there is a custom_components directory in config directory. So if I create it, can the systerm load it?
so copy the custom component into the folder and configure it
thx a lot!
thx, it works for me !
