How can I access the Hassio through Windows?
How can I access the Hassio through Windows as in this video? HASSIO is not in my Networks section.
I guess that one is Samba share. Personally I use FTP with Filezilla which I consider safer.
https://youtu.be/qnCRcGTznXs?t=330 - I followed the instructions in this video.
  "workgroup": "HOME",
  "name": "hassio",
  "guest": false,
  "map": {
    "config": true,
    "addons": true,
    "ssl": false,
    "share": true,
    "backup": true
  "username": "YOUR_USERNAME",
  "password": "YOUR_PASSWORD",
  "interface": "eth0",
  "allow_hosts": [
    "10.0.0.0/8",
    "172.16.0.0/12",
    "192.168.0.0/16"
When I press the save button. Confic changes to this:
  "allow_hosts": [
    "10.0.0.0/8",
    "172.16.0.0/12",
    "192.168.0.0/16"
What is the problem?
Samba's Log
[INFO] Read hostname: hassio
Registered MSG_REQ_POOL_USAGE
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
No builtin backend found, trying to load plugin
tdbsam_open: Converting version 0.0 database to version 4.0.
tdbsam_convert_backup: updated /var/lib/samba/private/passdb.tdb file.
tdb(/var/lib/samba/winbindd_idmap.tdb): tdb_open_ex: could not open file /var/lib/samba/winbindd_idmap.tdb: No such file or directory
tdb(/var/lib/samba/account_policy.tdb): tdb_open_ex: could not open file /var/lib/samba/account_policy.tdb: No such file or directory
account_policy_get: tdb_fetch_uint32_t failed for type 1 (min password length), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 2 (password history), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 3 (user must logon to change password), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 4 (maximum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 5 (minimum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 6 (lockout duration), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 8 (bad lockout attempt), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 10 (refuse machine password change), returning 0
Added user YOUR_USERNAME.
nmbd version 4.8.8 started.
Copyright Andrew Tridgell and the Samba Team 1992-2018
added interface eth0 ip=2001:14bb:430:a9ae:24fb:6510:a577:2 bcast= netmask=ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff
added interface eth0 ip=2001:14bb:430:a9ae:62fd:a0d0:335:b31e bcast= netmask=ffff:ffff:ffff:ffff::
added interface eth0 ip=fd24:fb65:10a5:7700:a5d3:1a4a:7f02:cdc0 bcast= netmask=ffff:ffff:ffff:ffff::
added interface eth0 ip=192.168.1.118 bcast=192.168.1.255 netmask=255.255.255.0
making subnet name:192.168.1.118 Broadcast address:192.168.1.255 Subnet mask:255.255.255.0
create_subnets: ignoring non IPv4 interface.
making subnet name:UNICAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
making subnet name:REMOTE_BROADCAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
load_lmhosts_file: Can’t open lmhosts file /etc/samba/lmhosts. Error was No such file or directory
daemon_ready: STATUS=daemon ‘nmbd’ finished starting up and ready to serve connections
smbd version 4.8.8 started.
Processing section “[config]”
Processing section “[addons]”
Processing section “[ssl]”
Processing section “[share]”
Processing section “[backup]”
INFO: Profiling support unavailable in this build.
tdb(/var/lib/samba/registry.tdb): tdb_open_ex: could not open file /var/lib/samba/registry.tdb: No such file or directory
daemon_ready: STATUS=daemon ‘smbd’ finished starting up and ready to serve connections
waiting for connections
check_for_master_browser_fail: Forcing election on workgroup HOME subnet 192.168.1.118
send_election_dgram: Sending election packet for workgroup HOME on subnet 192.168.1.118
run_elections: >>> Won election for workgroup HOME on subnet 192.168.1.118 <<<
become_local_master_browser: Starting to become a master browser for workgroup HOME on subnet 192.168.1.118
Samba name server HASSIO is now a local master browser for workgroup HOME on subnet 192.168.1.118
System log
19-07-05 21:38:17 WARNING (MainThread) [hassio.addons.validate] Unknown options certfile
19-07-05 21:38:17 WARNING (MainThread) [hassio.addons.validate] Unknown options keyfile
19-07-05 21:38:17 WARNING (MainThread) [hassio.addons.validate] Unknown options ssl
19-07-05 21:38:17 WARNING (MainThread) [hassio.addons.validate] Unknown options allowed_networks
19-07-05 21:38:17 WARNING (MainThread) [hassio.addons.validate] Unknown options banned_ips
19-07-05 21:38:17 WARNING (MainThread) [hassio.addons.validate] Unknown options banlimit
19-07-05 21:38:17 WARNING (MainThread) [hassio.addons.validate] Unknown options username
19-07-05 21:38:17 WARNING (MainThread) [hassio.addons.validate] Unknown options password
19-07-05 21:39:08 WARNING (MainThread) [hassio.addons.validate] Unknown options username
19-07-05 21:39:08 WARNING (MainThread) [hassio.addons.validate] Unknown options password
19-07-05 21:39:08 WARNING (MainThread) [hassio.addons.validate] Unknown options certfile
19-07-05 21:39:08 WARNING (MainThread) [hassio.addons.validate] Unknown options keyfile
19-07-05 21:39:08 WARNING (MainThread) [hassio.addons.validate] Unknown options ssl
19-07-05 21:39:08 WARNING (MainThread) [hassio.addons.validate] Unknown options allowed_networks
19-07-05 21:39:08 WARNING (MainThread) [hassio.addons.validate] Unknown options banned_ips
19-07-05 21:39:08 WARNING (MainThread) [hassio.addons.validate] Unknown options banlimit
19-07-05 21:40:13 INFO (SyncWorker_11) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-configurator with version 3.4
19-07-05 21:40:19 WARNING (MainThread) [hassio.addons.validate] Unknown options username
19-07-05 21:40:19 WARNING (MainThread) [hassio.addons.validate] Unknown options password
19-07-05 21:40:19 WARNING (MainThread) [hassio.addons.validate] Unknown options certfile
19-07-05 21:40:19 WARNING (MainThread) [hassio.addons.validate] Unknown options keyfile
19-07-05 21:40:19 WARNING (MainThread) [hassio.addons.validate] Unknown options ssl
19-07-05 21:40:19 WARNING (MainThread) [hassio.addons.validate] Unknown options allowed_networks
19-07-05 21:40:19 WARNING (MainThread) [hassio.addons.validate] Unknown options banned_ips
19-07-05 21:40:19 WARNING (MainThread) [hassio.addons.validate] Unknown options banlimit
19-07-05 21:40:27 INFO (MainThread) [hassio.ingress] Update Ingress as panel for core_configurator
19-07-05 21:41:30 WARNING (MainThread) [hassio.addons.validate] Unknown options username
19-07-05 21:41:30 WARNING (MainThread) [hassio.addons.validate] Unknown options password
19-07-05 21:41:30 WARNING (MainThread) [hassio.addons.validate] Unknown options certfile
19-07-05 21:41:30 WARNING (MainThread) [hassio.addons.validate] Unknown options keyfile
19-07-05 21:41:30 WARNING (MainThread) [hassio.addons.validate] Unknown options ssl
19-07-05 21:41:30 WARNING (MainThread) [hassio.addons.validate] Unknown options allowed_networks
19-07-05 21:41:30 WARNING (MainThread) [hassio.addons.validate] Unknown options banned_ips
19-07-05 21:41:30 WARNING (MainThread) [hassio.addons.validate] Unknown options banlimit
19-07-05 21:42:06 INFO (SyncWorker_19) [hassio.docker.interface] Stop addon_core_configurator application
19-07-05 21:42:08 INFO (SyncWorker_19) [hassio.docker.interface] Clean addon_core_configurator application
19-07-05 21:42:08 INFO (SyncWorker_19) [hassio.docker.interface] Remove image homeassistant/armv7-addon-configurator with latest and 3.4
19-07-05 21:42:09 INFO (MainThread) [hassio.addons.addon] Remove add-on data folder /data/addons/data/core_configurator
19-07-05 21:43:13 INFO (MainThread) [hassio.addons] Create Home Assistant add-on data folder /data/addons/data/core_configurator
19-07-05 21:43:13 INFO (SyncWorker_1) [hassio.docker.interface] Pull image homeassistant/armv7-addon-configurator tag 3.4.
19-07-05 21:44:00 INFO (SyncWorker_1) [hassio.docker.interface] Tag image homeassistant/armv7-addon-configurator with version 3.4 as latest
19-07-05 21:44:58 WARNING (MainThread) [hassio.addons.validate] Unknown options username
19-07-05 21:44:58 WARNING (MainThread) [hassio.addons.validate] Unknown options password
19-07-05 21:44:58 WARNING (MainThread) [hassio.addons.validate] Unknown options certfile
19-07-05 21:44:58 WARNING (MainThread) [hassio.addons.validate] Unknown options keyfile
19-07-05 21:44:58 WARNING (MainThread) [hassio.addons.validate] Unknown options ssl
19-07-05 21:44:58 WARNING (MainThread) [hassio.addons.validate] Unknown options allowed_networks
19-07-05 21:44:58 WARNING (MainThread) [hassio.addons.validate] Unknown options banned_ips
19-07-05 21:44:58 WARNING (MainThread) [hassio.addons.validate] Unknown options banlimit
19-07-05 21:49:10 WARNING (MainThread) [hassio.addons.validate] Unknown options username
19-07-05 21:49:10 WARNING (MainThread) [hassio.addons.validate] Unknown options password
19-07-05 21:49:10 WARNING (MainThread) [hassio.addons.validate] Unknown options certfile
19-07-05 21:49:10 WARNING (MainThread) [hassio.addons.validate] Unknown options keyfile
19-07-05 21:49:10 WARNING (MainThread) [hassio.addons.validate] Unknown options ssl
19-07-05 21:49:10 WARNING (MainThread) [hassio.addons.validate] Unknown options allowed_networks
19-07-05 21:49:10 WARNING (MainThread) [hassio.addons.validate] Unknown options banned_ips
19-07-05 21:49:10 WARNING (MainThread) [hassio.addons.validate] Unknown options banlimit
19-07-05 21:49:33 WARNING (MainThread) [hassio.addons.validate] Unknown options username
19-07-05 21:49:33 WARNING (MainThread) [hassio.addons.validate] Unknown options password
19-07-05 21:49:33 WARNING (MainThread) [hassio.addons.validate] Unknown options certfile
19-07-05 21:49:33 WARNING (MainThread) [hassio.addons.validate] Unknown options keyfile
19-07-05 21:49:33 WARNING (MainThread) [hassio.addons.validate] Unknown options ssl
19-07-05 21:49:33 WARNING (MainThread) [hassio.addons.validate] Unknown options allowed_networks
19-07-05 21:49:33 WARNING (MainThread) [hassio.addons.validate] Unknown options banned_ips
19-07-05 21:49:33 WARNING (MainThread) [hassio.addons.validate] Unknown options banlimit
19-07-05 21:49:34 WARNING (MainThread) [hassio.addons.validate] Unknown options username
19-07-05 21:49:34 WARNING (MainThread) [hassio.addons.validate] Unknown options password
19-07-05 21:49:34 WARNING (MainThread) [hassio.addons.validate] Unknown options certfile
19-07-05 21:49:34 WARNING (MainThread) [hassio.addons.validate] Unknown options keyfile
19-07-05 21:49:34 WARNING (MainThread) [hassio.addons.validate] Unknown options ssl
19-07-05 21:49:34 WARNING (MainThread) [hassio.addons.validate] Unknown options allowed_networks
19-07-05 21:49:34 WARNING (MainThread) [hassio.addons.validate] Unknown options banned_ips
19-07-05 21:49:34 WARNING (MainThread) [hassio.addons.validate] Unknown options banlimit
19-07-05 21:50:04 INFO (SyncWorker_19) [hassio.docker.interface] Remove image homeassistant/armv7-addon-configurator with latest and 3.4
19-07-05 21:50:05 INFO (MainThread) [hassio.addons.addon] Remove add-on data folder /data/addons/data/core_configurator
19-07-05 21:50:37 INFO (MainThread) [hassio.addons] Create Home Assistant add-on data folder /data/addons/data/core_samba
19-07-05 21:50:37 INFO (SyncWorker_17) [hassio.docker.interface] Pull image homeassistant/armv7-addon-samba tag 8.1.
19-07-05 21:51:00 INFO (SyncWorker_17) [hassio.docker.interface] Tag image homeassistant/armv7-addon-samba with version 8.1 as latest
19-07-05 21:52:50 WARNING (MainThread) [hassio.addons.validate] Unknown options name
19-07-05 21:52:50 WARNING (MainThread) [hassio.addons.validate] Unknown options guest
19-07-05 21:52:50 WARNING (MainThread) [hassio.addons.validate] Unknown options map
19-07-05 21:53:00 INFO (SyncWorker_0) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-samba with version 8.1
19-07-05 21:54:28 INFO (SyncWorker_4) [hassio.docker.interface] Stop addon_core_samba application
19-07-05 21:54:29 INFO (SyncWorker_4) [hassio.docker.interface] Clean addon_core_samba application
19-07-05 21:54:33 INFO (SyncWorker_19) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-samba with version 8.1
19-07-05 22:04:15 WARNING (MainThread) [hassio.addons.validate] Unknown options name
19-07-05 22:04:15 WARNING (MainThread) [hassio.addons.validate] Unknown options guest
19-07-05 22:04:15 WARNING (MainThread) [hassio.addons.validate] Unknown options map
19-07-05 22:04:27 INFO (SyncWorker_3) [hassio.docker.interface] Stop addon_core_samba application
19-07-05 22:04:28 INFO (SyncWorker_3) [hassio.docker.interface] Clean addon_core_samba application
19-07-05 22:04:31 INFO (SyncWorker_5) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-samba with version 8.1
19-07-05 22:04:33 WARNING (MainThread) [hassio.addons.validate] Unknown options name
19-07-05 22:04:33 WARNING (MainThread) [hassio.addons.validate] Unknown options guest
19-07-05 22:04:33 WARNING (MainThread) [hassio.addons.validate] Unknown options map
In windows explorer type
\\192.168.x.x
(ie the ip of your hassio machine.
FTP isn’t safer at all, and being on your Local Area Network, you should be trusting your devices.
I know people hate hearing this, but Windows sucks. Sometimes it doesn’t show things on the network. It’s ok, because things are easy to type with a keyboard like the IP address of the hassio machine…which you should do instead of relying on Windows to “find” it.
That worked!
But why is the code not saved correctly in the Config section? It always changes to this:
  "username": "XXX",
  "password": "XXX",
  "allow_hosts": [
    "10.0.0.0/8",
    "172.16.0.0/12",
    "192.168.X.X/16"
In addition, I tried to install the Configurator add-on:
  "username": "XXX",
  "password": "XXX",
  "certfile": "fullchain.pem",
  "keyfile": "privkey.pem",
  "ssl": false,
  "allowed_networks": [
    "192.168.X.X/16"
  "banned_ips": [
    "8.8.8.8"
  "banlimit": 0,
  "ignore_pattern": [
    "__pycache__"
  "dirsfirst": false
Error message:
not a valid value for dictionary value @ data[‘options’]. Got {‘username’: ‘PatrikSelin’, ‘password’: ‘5oxvmM:4ez’, ‘certfile’: ‘fullchain.pem’, ‘keyfile’: ‘privkey.pem’, ‘ssl’: False, ‘allowed_networks’: [‘192.168.1.118/16’], ‘banned_ips’: [‘8.8.8.8’], ‘banlimit’: 0, ‘ignore_pattern’: [‘pycache’], ‘dirsfirst’: False}
Why is it difficult to save code?
Probably the : in your password.
You are using old out of date instructions from somewhere that have options that don’t exist anymore.
Tap default in the addon and it will show currently valid options.
I meant to say that I use Filezilla with a SSh private key file. So ignoring the obvious improbable network intrusion scennario, it’s safer on the simple fact that your wife or your kid cannot do nothing on the pi without the physical key file. It’s easier drop something on a incorrect folder. i consider it as practical as Samba with this important twitch.
Thanks for this! I am a new user, so I will ask silly questions.
