How Can I add Button to Add control/Switch Operation modes (auto, silent, favorite, idle)
I am new to Home assistant
I managed to add Xiaomi Air purifier 2 to HA successfully!!
I am able to ON & OFF the device using Home Assistant UI
I want to add a button(s) to change the Operation Mode of the Xiaomi Air purifier 2 in Home assistant for which I have created Input select options with modes ‘Auto’, ‘Silent’, ‘Favorite’
Now I have the following issues.
  1. I am Not able to trigger the Mode change from any options that are selected in Input select.
    The automation is not able to call the service FAN.SET_SPEED
    As per documentation , I understand we can call the following
    Fan speed. Valid values are ‘Auto’, ‘Silent’, ‘Favorite’ and ‘Idle’
    But am not able to call that service.
  2. Can we have Input select options as radio button or slider instead of a drop-down list?
    Please guide me
    Thanks in advance
Why not?
You should be able to, why aren’t you able to?
Here is my automation code
  • id: ‘1530286583234’
    alias: Test
    • entity_id: input_select.who_cooks
      platform: state
      to: High Speed Mode
      condition: []
    • data:
      entity_id: fan.xiaomi_air_purifier
      service: fan.set_speed
But am not sure where & how to call the modes ( ‘Auto’, ‘Silent’, ‘Favorite’ and ‘Idle’)
When posting logs or configuration snippets please use code blocks and syntax highlighting.
My automations.yaml
Blockquote
  • id: ‘1530192351578’
    alias: ON Purifier When TV ON ONLY Evening
    • entity_id: switch.tv
      platform: state
      to: ‘on’
      condition:
    • after: ‘18:00:00’
      before: 06:00:00
      condition: time
    • alias: ‘’
      service: fan.turn_on
    alias: Test
      platform: state
      to: High Speed Mode
      condition:
    • data:
      My configuration.yaml
Blockquote
homeassistant:
Name of the location where Home Assistant is running
name: Chaku’s Home Automation
Location required to calculate the time the sun rises and sets
latitude: 13.0833
longitude: 80.2833
Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 9
metric for Metric, imperial for Imperial
unit_system: metric
Pick yours from here: List of tz database time zones - Wikipedia
time_zone: Asia/Kolkata
Customization file
customize: !include customize.yaml
Show links to resources in log and frontend
#introduction:
Enables the frontend
frontend:
mqtt:
broker: core-mosquitto
username: admin
password: admin
switch 01:
platform: mqtt
command_topic: “cmnd/sonoff00/power”
state_topic: “stat/sonoff00/POWER”
qos: 1
payload_on: “ON”
payload_off: “OFF”
retain: true
switch 02:
platform: mqtt
name: “Walk Way Light”
command_topic: “cmnd/sonoff01/power”
state_topic: “stat/sonoff01/POWER”
qos: 1
payload_on: “ON”
payload_off: “OFF”
retain: true
fan:
Example configuration.yaml entry zhimi.airpurifier.m1
  • platform: xiaomi_miio
    host: 192.168.1.19
    token: 0cbc1f1294290ff7ee51d7667a5a17a9
    name: Xiaomi Air Purifier
panel_iframe:
configurator:
title: Configurator
icon: mdi:wrench
url: http://192.168.1.111:3218
Enables configuration UI
config:
http:
Secrets are defined in the file secrets.yaml
api_password: !secret http_password
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
base_url: example.duckdns.org:8123
Checks for available updates
Note: This component will send some information about your system to
the developers to assist with development of Home Assistant.
For more information, please see:
Explaining the Updater - Home Assistant
updater:
Optional, allows Home Assistant developers to focus on popular components.
include_used_components: true
Discover some devices automatically
discovery:
Allows you to issue voice commands from the frontend in enabled browsers
conversation:
Enables support for tracking state changes over time
history:
View all events in a logbook
logbook:
Enables a map showing the location of tracked devices
map:
Track the sun
sun:
Weather prediction
- platform: yr
  • platform: template
    sensors:
    airpurifier_aqi:
    friendly_name: Xiaomi Air Quality Index
    value_template: ‘{{ states.fan.xiaomi_air_purifier.attributes.aqi }}’
    airpurifier_temperature:
    friendly_name: Temperature
    value_template: ‘{{ states.fan.xiaomi_air_purifier.attributes.temperature }}’
    airpurifier_humidity:
    friendly_name: Xiaomi Humidity
    value_template: ‘{{ states.fan.xiaomi_air_purifier.attributes.humidity }}’
    airpurifier_mode:
    friendly_name: Air Purifier Mode
    value_template: ‘{{ states.fan.xiaomi_air_purifier.attributes.mode }}’
    airpurifier_filter_life_remaining:
    friendly_name: Air Purifier Life Remaning
    value_template: ‘{{ states.fan.xiaomi_air_purifier.attributes.filter_life_remaining }}’
Text to speech
tts:
  • platform: google
Cloud
cloud:
#group: !include groups.yaml
Define our dropdown list
input_select:
who_cooks:
options:
- Auto Mode
- Night Mode
- High Speed Mode
initial: Auto Mode
icon: mdi:speedometer
switch 03:
platform: broadlink
host: 192.168.1.2
mac: ‘78:0f:77:00:ac:fa’
timeout: 115
friendly_name: Broadlink Universal Remote
switches:
tv:
friendly_name: “Micromax Tv Power”
command_on:
‘JgBYAAABLpQTExQSEhMTExQSEhMUNhQSEzcSOBM3EzcTNxM3ExMUNhMTEjgUERQSEzcUEhITExMTNxMTEjgSOBITEzcTNxM4EgAFJgABL0kUAAxgAAEuSxQADQU=’
command_off:
‘JgBYAAABL5QUEhQSExMSExMTFBITNxMTEzcTNxM3EzcUNxI4ExITNxMTFDYTExMTEjgUEhITExMTNxMTEzcUNhQSEjgUNhI4EwAFJQABL0oTAAxhAAEwSRQADQU=’
Here’s an example:
Configuration.yaml
fan:
  - platform: xiaomi_miio
    host: 192.168.178.78
    token: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Automation.yaml
- alias: 'Turn off air purifier when door opens between 7am and 5pm'
    - platform: state
      entity_id: binary_sensor.door_window_sensor_158d0001f38b1f
      to: 'on'
  condition:
    - condition: time
      before: '17:00:00'
      after: '07:00:00'
    - service: fan.set_speed
      entity_id: fan.xiaomairpurifier
        speed: 'idle'
Works like a Charm. Thanks a bunch
Few Questions:
  1. Can we have Input select as Radio Buttons ?
    Now it’s by default its Drop down only
  2. I see you have added binary_sensor.door_window_sensor , which I understand as generic 433Mhz Door sensor.
    How did you manage to add that to Home assistant? Any Tutorial link?
    Thanks in advance
  1. looks like a xiaomi sensor to me (from the default name it has been given).
setup an automation using trigger, platform state, input_select
then you can change fan when input_select changes state
xiaomi zigbee door sensor
Thanks a lot
