Im A Total Newbie in Home Assistant…
In the Learning Process…
Recently Started Home Assistant OS Using A Home Assistant Green…
So Far i been able to add several Devices using integrations including Tuya , Smarthings , and Alexa …
But I Cant Find an integration For Aqara Producs…
And i have alot of Aqara devices …
Does anyone Knows or have any idea how can i add or integrate the aqara home app or the Aqara M2 hub to Home Assistant ?
I Already Tried Binding The Aqara M2 Hub with the Matter integration in Home Assistant and it works !..
But Very limited…
The Matter Integration doesn’t expose all the devices capabilities …
Devices only expose the very basic cores
For example My Aqara P1 Sensors olny shows or expose the motion Part of the sensors but doesn’t show the Illuminance Capabilities …
And The Temperature & Humidity Sensors only shows or expose The Temperature Part of the sensors but doesnt show or expose The Humidity part part of the sensor …
I guess those are called Entities?
Ohh Well ! Im Trying to Learn…
In My Particular situation i need The Illuminance Capabilities For my Automations and my Scenes…
I Know I Still have a long Way To Go…" and a lot to Learn ! But ill get there …
Eventually…
In The Meantime…
Could anyone help me solve This Dilema ?
Any Help will be Greatly Apreciated…
You don’t pair apps with home assistant, only the hubs.
Have you tried this?
Otherwise:
You could un-pair your devices from the hub and sell it. Pair them directly with a zigbee coordinator dongle connected to Home Assistant and use ZHA or Zigbee2MQTT.
tom_l … Thank you very much For your quick reply !
Thanks so much for the information…
Option # 1…is too advance for me rigth now…
And sounds like my Aqara devices may or may not work…
And option #2… is a sad option since i have to ged rid of all my Aqara devices… And start buying new ones…as a matter of fact today i got my brand new Aqara M2 Hub and A brand new Aqara SP2 sensor…
They are Awesome… ! And work incredible well…
But ! …No Home Assistant Compatibility " yet "
So that means i have no other choice in the matter !
You Mentioned that by adding a Zigbee Dongle like the Skyconnect to my home assistant green usb port i can add my Aqara devices to home assistant ?
If i go this route…
Would home assistant show the Aqara sensors as multiple entities or just as one funtion or just one part of sensor ?..
What i mean is if my Aqara P1 Motion sensors will show in home assistant as motion and Illuminance as well …
And The Aqara Temperature & Humidity Sensors will show both Temperature and humidity Or will show just temperature ?
I know its sounds confusing!
My apologies for my lack of knowledge…
Same boat as you pal! Except I started my journey a couple weeks ago.
I added my M2 hub to HA using the Homekit devices integration.
This then exposes the devices and all entities of said devices to HA, WHILE keeping the Aqara app/hub going for the extra bit of control/customisation you don’t quite get outside the Aqara ecosystem (preset effects of the T1M I recently installed being a prime example).
Through the Homekit integration you get the most exposed to HA compared to ZHA and definitely way more than with matter.
It also means all Aqara devices should show up in HA with all entities exposed, once you’ve paired a device to the M2 hub.
Bonus point is you still receive firmware upgrades for the devices through the Aqara app/hub.
Fyi, you do not need an iPhone to do this or set any of it up, as I did this using my Android.
Any other questions, then lmk.
As I have had this setup running nicely for the last week or so, no complaints at all, just need setup my automations in HA with it now that I am happy connectivity and control is setup in the most functional and flexible manner.
No need to reset the hub. As long as your M2 hub is correctly setup with devices connected, following HomeKit Bridge - Home Assistant should get you what you need.
See my screenshot and follow the steps from there. You need to hold the pairing button on you hub for 6 seconds or something to get it in Homekit pairing mode, but a quick Google will tell you for sure.
I have no experience with the other coordinators, other than seeing issues often reported on the forum. Tube’s coordinator has been working perfectly for me for years. He also offers responsive and helpful support.
This worked perfectly, only problem was that the M2 hub refused to finish the update, until i logged in, and in my instance i ended up needing to go around and find all my temperature sensors, and locate them in my app, that is ultimately going to be a minor gripe though, because of the features that come with exposing them to home-assistant, overall a win
Do you mean the video contained the process that worked for you or the post above on pairing through HomeKit devices? I recently posted a new thread asking the benefits of one over the other, would be keen to hear your thoughts
