How Can I Add This Weather Radar to Lovelace?
I’m trying to match some of the things I liked from my touch panels to my Lovelace setup and I’ve hit one snag. I have a weather radar map
I add this to the webpage card configuration, but nothing I try will display the full image. All I get is the upper left corner of it regardless of aspect ratio or percentage setting.
Is there a way to get this displayed fully?
Maybe with a new view in panel mode and then a webpage card?
I did this. I set up a new page, added the webcard, made it 1 panel, and this is what I got. May not be what you want or the correct url.
Webcard
Page:
Actual view:
Here is the URL I used
https://6abc.com/weather/doppler/stormtracker-6---regional-view/
Ok, but then the problem is because of the source since the link refers to the whole page instead of the map only.
You could try to link to the image only and see if it gets updated.
Yeah, I got that, but that’s way more than I was looking for and on a 10" display I’d just want the image.
The goal is a live radar map of the area so any source is fine, and animated radar would be preferred. I thought about using Windy, but the look (to me) is just way too busy and not just a simple radar. Plus it’s not current and only updates every few hours or more.
That’s what I did above. It’s just the image, but I still can’t display the whole thing.
This is the link to the image only: https://cdns.abclocal.go.com/three/wpvi/weather/regionalradar10_1280.jpg
You are using the whole webpage as a link.
EDIT: I have set it up as a new view in panel mode and then ad a webpage card with the image url and 100% aspect ratio.
And indeed it gets updated but don’t know if it’s automatically. (with a browser refresh I get the same result as the source)
Thanks! That did it. Next up is to figure out how I had it animating in ActionTiles (for SmartThings)…
Glad it worked, maybe you can mark this thread as solved.
Just out of curiosity: you are using HA and what is the reason for having that smartthings hub?
About animating the weather card: maybe there is a way to refresh that view/card in HA.
It’s how it WAS being used as I previously had a SmartThings setup. Today that hub is gone.
Hi, you still didn’t close this topic as solved.
Please take the time to mark the answer as solution, you do that by selecting the three dots under the post:
Then select the check box:
This can be useful to other users as well and prevents that someone else steps in to try to help you.
