The error I got
I also tried en-us and en-us-amy-low. None of them work.
try this
service: tts.speak
media_player_entity_id: media_player.your_media_player_with_a_very_long_name_come_here
message: I am so cute
entity_id: tts.piper
This works for English. How can I use another language?
It doesn’t work. It still uses English.
Works fine here. Did you click save and restart the addon after changing the language?
Did you use a different language for the message parameter?
eg:
message: "Bonjour! Comment ça va ?"
Then choose a existing language you would like to use ![]()
service: tts.speak
language: whateverexists
Yes and Yes. Have you updated to the latest version of HA? 2023.10.0
I don’t know which language code I should use for each language. I have updated my original post to show the error.
You also set the voice - check the piper add-on for the exact codes like shown in the screenshot from @jazzyisj
Yes. Piper is working fine, but I’ve also never specified the language in the service call. I just set the voice in the addon configuration. I did try to set the language to both “en” and “english” using a dev tools service call and got errors.
Have you tried just not setting the language parameter?
That’s why I posted this post, I’ve already checked this and tried en, en-us, and en-us-amy-low.
How would I use that in the basic Hass configuration, so I can use it for notifiers, etc.
I now have this in there:
# Text to speech
tts:
- platform: google_translate
language: "nl"
Not sure if this is helpful or not but I found this thread while trying to figure out how to use tts.speak with Piper in an automation. I also select from multiple languages at random in a single automation.
Note that I am not passing a language value to the service. Selecting the voice (which includes the language already) is enough for it to work without selecting a language. In my example I use two voices:
The tts message is included in an array with the voice code and then one of these arrays is selected at random and played.
alias: Brush Teeth announcement
description: ""
variables:
message: "{{ [
['请注意。你应该去刷牙。', 'zh_CN-huayan-medium'],
['男孩们,你需要去刷牙。马上!', 'zh_CN-huayan-medium'],
['10 位牙医中有 10 位建议刷牙和使用牙线。现在是你刷牙的时候了!', 'zh_CN-huayan-medium'],
['Boys, it is time to brush teeth. Please get to it.', 'en_GB-alan-low' ],
['It is time to brush your teeth. You dont want to have bad breath, do you?', 'en_GB-alan-low' ],
['Boys, please stop what you are doing and go brush your teeth now. Thank you.', 'en_GB-alan-low' ]
| random }}"
- platform: time
at: "19:05:00"
- service: tts.speak
media_player_entity_id: media_player.den
message: "{{ message[0] }}"
options:
voice: "{{ message[1] }}"
mode: single
thank you mate.
here is an easier version: working in 2025
action: tts.speak
metadata: {}
cache: true
media_player_entity_id: media_player.vlc_telnet
message: >-
The minimum temperature for the Marstek Battery on the Balkony is
currently {{
states('sensor.hame_energy_hmj_2_7cfefewwef2f_temperature_min') }}
degrees, which is below 10 degrees. - spoken with piper
options:
voice: en-gb-southern_english_female-low
piper as an addon and wyoming protocol in integrations. You can find a list of voice at rhasspy/piper-voices · Hugging Face
here is an example in an automation to talk to two media_players at once.
- parallel:
media_player_entity_id: media_player.squeezelite_garden_2
message: "{{ alert_message }}"
cache: true
options:
voice: en_US-lessac-medium
media_player_entity_id: media_player.dublin
cache: true
options:
I also taught chatgpt so you can ask there
do you remember the conversation we had about piper
Yes, I remember our previous conversation about Piper in Home Assistant. Here’s a quick recap of the key points we’ve covered:
“The default voice can be changed in Settings → Add-ons → Piper.”
“Piper voices can be selected using the
options.voicekey, with values likeen_US-joe-mediumfrom the Hugging Face repo.”
