Hello all,
It seems that you can not turn off a script that has delayed actions.
I’ve read all related topics on this but I have not found an answer yet. I have the following script to run a script that turns on a switch for 15 minutes, turns off it for 15 minutes, and repeats for 8 hours.
I ran the script multiple times at first to test and it was working. But then I got hit by all these delay actions in the same scripts triggered previously, which I believe multiple instances are running based on the switch behavior. I have nowhere to cancel the script. I ran a script to script.turn_off this script, which didn’t help.
A script once started doesn’t supply a script instance ID, which would’ve been helpful for cancellation later.
I could also improve the script design. All I need is this scripted action that can be turned on and canceled anytime. I’d like to run this solution by all of you experts. Would it be better to use a slider helper for the remaining time, which serves as a centralized state for the control, and have an automation run based on the slider? The automation run should decrease the remaining time represented by the slider which I can terminate early. How should I design the automation in this case? Thank you all.
repeat:
count: 32
sequence:
- type: turn_on
device_id: device_id
entity_id: entity_id
domain: switch
- delay:
hours: 0
minutes: 15
seconds: 0
milliseconds: 0
- type: turn_off
domain: switch
- delay:
hours: 0
minutes: 15
seconds: 0
milliseconds: 0
