Home Assistant 11.5 install didn’t offer to change to a friendly name.
So I changed in Dashboard → Sensor → Configuration → entity sensor.0xa4c1385ecf65906f_humidity to sensor.humidity and now there’s error: Entity not available: sensor.0xa4c1385ecf65906f_humidity
I found the solution in:
Home Assistant 11.5 → Settings → Add-one → Zigbee2MQTT → OPEN WEB UI → Rename device → Friendly name.
