The card in the picture is the Simple Thermostat which has up/down arrows for changing the temperature.
I’d like to have a separate input_number that can be controlled similarly.
I don’t want to use a slider because it’s hard to be precise with that. I find myself constantly overshooting the value I want and trying to nudge it back and forth until I finally get the correct number.
I’d also like to use a similar UI because the input_number will be used for scheduling temperature changes. It would be nice if the controls looked the same.
Thanks!
