Sorry I tried to figure it out from the documentation, but I don’t see any examples.
Thanks!
Isn’t it dealt with here? LVGL Graphics — ESPHome
I don’t think there is a setting for this in ESPhome.
Looks like the default is only 400ms. What did you want to set it to?
I guess you could use a lamda. I’m not 100% sure where this would go.
lv_indev_set_long_press_time(LV_INDEV_STATE_PR, 1000); // Set long press time to 1000ms
Thanks for the replies, I realized I don’t have access to this control because I have been dipping my feet into using ha deck, I will have to try going direct, if I can figure out the right board/driver combo. Thanks!
An I mistaken about what this does then?
long_press_time (Optional, Time): For the touchscreen, delay after which the on_long_pressed interaction trigger will be called. Defaults to 400ms.
sorry to resurrect an old thread - where does this bit of code actually go?
In the touchscreen or encoder config.
I’ve been using the on_press_long action in ESPHome, and it’s working well for me. However, I’d like to adjust the time duration before it triggers. I’ve followed the documentation to do so, but whenever I make changes, I’m getting unexpected results:
[long_press_time] is an invalid option for [touchscreen.gt911]
I have it defined under “touchscreens”:
touchscreens:
- touchscreen_id: my_touchscreen
long_press_time: 200ms
Hi, thanks!
I have this touchscreen config:
touchscreen:
platform: gt911
interrupt_pin: GPIO4
update_interval: 16ms
And this lvgl config:
lvgl:
displays: my_display
touchscreens: my_touch
buffer_size: 20%
color_depth: 16
log_level: DEBUG
For some reason, I’ve tried adding the long_press_time: 1000ms reference in each, but it keeps throwing an error. Not sure what I’m doing wrong.
under “lvgl” add “touchscreens” and “long press time”:
lvgl:
buffer_size: 20%
color_depth: 16
log_level: DEBUG
touchscreens:
Thanks again. I’m definitely going to have to take a closer look at my yaml, as there’s definitely something funky going on. Even the helper does not recognise long_press_time:.
