I just added a USB Bluetooth dongle, which apparently took down my USB stick. IIRC, I did not initially use device-by-id (or whatever the path is), and that’s why nothing worked.
So how do I change it to use the updated device path?
This depends on how you are running HA, ie. HA OS, docker, venv etc.
Good point. I downloaded the appliance file and am running it in a VM (and obviously passing in all USB devices).
edit: Wait. Does that even matter? Isn’t the setting inside the integrations themselves?
