How can I combine sensor data and time on a mqtt temperature/humidity sensor?
Dear HomeAssistant assistants,
I am having trouble getting the configurations right for my temperature and humidity sensors. The issue with me is, that I cannot connect sensor time to each temperature or humidity value.
Apologies, if this question was already asked or is explained in the documentation. I just couldn’t find it.
Here is what I receive via mqtt:
{"time" : "2024-10-15 12:49:12", "model" : "Ambientweather-F007TH", "id" : 29, "channel" : 6, "battery_ok" : 1, "temperature_C" : 20.722, "humidity" : 63, "mic" : "CRC"}
My non-working configuration looks like:
  - name: "Time Balcony"
    unique_id: "time_balkon"
    state_topic: "mqtt/sensors/balcony"
    value_template: "{{ value_json.time | as_datetime | as_local }}"
  - name: "Temperature Balcony"
    unique_id: "temperature_balcony"
    state_class: "measurement"
    unit_of_measurement: "°C"
    value_template: "{{ value_json.temperature_C }}"
  - name: "Humidity Balcony"
    unique_id: "humidity_balcony"
    unit_of_measurement: "%"
    value_template: "{{ value_json.humidity }}"
  - name: "battery balcony"
    unique_id: "battery_balcony"
    device_class: "binary_sensor"
    value_template: "{{ value_json.battery_ok }}"
Can someone please guide me on how to set this up properly?
Let me try to explain this better.
My json-data from the physical temperature/humidity sensor
contains time, temperature and humidity values among others. In my current settings, my entities in home assistant use the reception time for their time axes. This is not what i want. I would rather like to use the actual time values from json-data.
How can i achieve this?
