Hello HA masters
I have bought this little RF433 button from AliExpress
https://www.aliexpress.com/item/1005007463319446.html
I didnt buy the RF relay part, , I only want to use the button part as on demand RF button. to detect only when its pressed ( I understand that the button does not send anything while not being used)
Im reading it from Li=ligo32 module which also reads other RF433 sensors from my home
for some reason its being detected as smoke alert sensor in MQTT explorer and creates a smoke alert sensor in HA but only with sinbgle entity of RSSI, no on/off state entity
see MQTT JSON
{"model":"Smoke-GS558","id":13550,"unit":1,"learn":0,"code":"169dc1","protocol":"Wireless Smoke and Heat Detector GS 558","rssi":-93,"duration":1307000}
What i noticed is when i press the button a button the RSSI gets sent to MQTT and HA
but no other status is updated in the JSON
but thats the only thing updated
is there a way to configre the MQTT somehow on how to parse this to be able to detect the button ?
thanks in advance!
