Hi, I‘m using a raspberry pi for my home assistant system. I like to connect tuya bluetooth temperature sensor with home assistant directly or via a bluetooth proxy.
I‘m able to integrate the sensor in „Smart Life“ app and actually I thought it‘s very easy to connect it also with home assistant.
What have I done?
- ESP home is already installed and works (I have a working connection to other devices)
- Sensor is very close to Atom/raspberry
- unfortunately home assistant can’t find the sensor
Can it be that my device is not appropriate to connect it to my home assistant?
I know there is a way to connect the sensor with „Smart Life“ app and integrate all devices via this app in home assistant. But in this case I have to be at home to get and bring data from sensor into home assistant. But I also need the temperature if I’m not on the road:-)
