Only thing I can think of is, that your climate entity does not support statistics. But it is out of my knowledge to determine, if that is the problem.
How can I remove the legend? I understand in a “history-graph” this is not possible.
I have the following climate entity and a sensor. The climate entity has 3 values, while in the following graph it’s obvious the 3 values is the target temperature and the single line the current temperature in the room. A title is enough…
Gives error:
Specify an entity from within the sensor domain
hours_to_show: 24 graph: line type: sensor entity: climate.gert_jan detail: 1
How can I make a sensor of a climate entity?
@ geepie The error points out that you did not provide an entity with a sensor domain. If you go to the device page of your home thermostat, do you see an sensor entity you can address within the card?
Also, some custom cards provide more customization. Like Mini Graph Card. This is also worth taking a look
