Hi guys!
When I wake up, I’d like to turn on some lights in sequence, and fade them in. Eg:
In 5 s, fade in light by bed over 10s to 50 brightness
In 30 s, fade in main light over 50s to 255 brightness
Etc. I thought I was being clever by iterating over them like this:
""" A list of lists containing:
Entity id, delay, fade duration
lights = [
["light.monitor", 2, 30],
["light.bathroom_2", 2, 20],
["light.reol_2", 2, 240],
["light.loft_2", 210, 300],
["light.gang", 60, 300],
for light in lights:
self.run_in(self.setstate,
light[1], <-- Delay
lt=light[0], <-- Entity ID
fade=light[2], <-- Fade time
switch="input_boolean.carpemieke" <-- Conditional switch)
def setstate(self, lt, brightness, fade, switch, color=""):
if self.get_state(switch) == "on":
self.log("Set " + lt + " to fade in over " + str(fade * self.modulator) + "s with \n Brightness: {}\n Kelvin: {}".format(brightness, color))
if color != "":
self.turn_on(lt, brightness=brightness, transition=self.modulator * fade, kelvin=color)
else:
self.turn_on(lt, brightness=brightness, transition=self.modulator * fade)
time.sleep(self.modulator * fade)
else:
self.log("Switch turned off, terminating")
However, this seems to result in thread starvation.
2019-05-13 07:53:08.537428 WARNING AppDaemon: Queue size is 10, suspect thread starvation
2019-05-13 07:53:08.537830 INFO AppDaemon: --------------------------------------------------
2019-05-13 07:53:08.538098 INFO AppDaemon: Threads
2019-05-13 07:53:08.538374 INFO AppDaemon: --------------------------------------------------
2019-05-13 07:53:08.538682 INFO AppDaemon: Currently busy threads: 20
2019-05-13 07:53:08.538988 INFO AppDaemon: Most used threads: 24 at 2019-05-10 21:10:53.252923
2019-05-13 07:53:08.539271 INFO AppDaemon: Last activity: 2019-05-12 23:09:54.492178
2019-05-13 07:53:08.539535 INFO AppDaemon: --------------------------------------------------
2019-05-13 07:53:08.540256 INFO AppDaemon: thread-1 - current callback: idle since 2019-05-10 21:27:44.252923, alive: False
2019-05-13 07:53:08.540602 INFO AppDaemon: thread-2 - current callback: idle since 2019-05-11 22:01:28.492178, alive: False
2019-05-13 07:53:08.540906 INFO AppDaemon: thread-3 - current callback: idle since 2019-05-12 23:09:54.492178, alive: False
2019-05-13 07:53:08.541209 INFO AppDaemon: thread-4 - current callback: idle since 2019-05-10 20:57:41.252923, alive: False
2019-05-13 07:53:08.541528 INFO AppDaemon: thread-5 - current callback: idle since 2019-05-10 21:03:12.252923, alive: False
2019-05-13 07:53:08.541842 INFO AppDaemon: thread-6 - current callback: idle since 2019-05-10 20:57:08.252923, alive: False
2019-05-13 07:53:08.542153 INFO AppDaemon: thread-7 - current callback: idle since 2019-05-11 22:01:28.492178, alive: False
2019-05-13 07:53:08.542452 INFO AppDaemon: thread-8 - current callback: idle since 2019-05-10 20:57:12.252923, alive: False
2019-05-13 07:53:08.542752 INFO AppDaemon: thread-9 - current callback: idle since 2019-05-10 21:29:44.252923, alive: False
2019-05-13 07:53:08.543053 INFO AppDaemon: thread-10 - current callback: idle since 2019-05-10 21:02:40.252923, alive: False
2019-05-13 07:53:08.543318 INFO AppDaemon: --------------------------------------------------
I’m guessing this is because the run_in commands aren’t assigned a handle, and therefore aren’t cleared as variables? Or perhaps my diagnosis is wrong? Any ideas?
Thanks!
