How can I disable the cloud component?
Here is the current list of default_config: components from manifest.json:
application_credentials:
automation:
cloud:
counter:
dhcp:
energy:
frontend:
history:
input_boolean:
input_button:
input_datetime:
input_number:
input_select:
input_text:
logbook:
map:
media_source:
mobile_app:
my:
network:
person:
scene:
script:
ssdp:
sun:
system_health:
tag:
timer:
usb:
webhook:
zeroconf:
zone:
My configuration.yaml now looks like this:
# Configure a default setup of Home Assistant (frontend, api, etc) #
#default_config:
#automation:
#cloud:
counter:
dhcp:
energy:
#frontend:
history:
input_boolean:
input_button:
input_datetime:
input_number:
input_select:
#input_text:
#logbook:
map:
media_source:
mobile_app:
my:
network:
person:
#scene:
#script:
ssdp:
sun:
system_health:
tag:
timer:
usb:
#webhook:
zeroconf:
#zone:
homeassistant:
  customize: !include customize.yaml
alexa: !include alexa.yaml
api:
(etc.)
Except for cloud:, the other commented items were due to duplicate keys as they were defined later in my config.
In my opinion it’s a pitty that cloud is in the default_config.
It’s okay when cloud: is in the standard configuration.yaml, but i don’t think many ha users want to use the cloud feature…
There’s a lot of stuff in default_config that shouldn’t be in there, as far as I see it. At least for advanced users.
I’m dealing with this by modifying the manifest.json, as @Aldaran mentioned. But instead of doing it manually, I run a custom post-install / post-update script that removes entries i don’t like from the json (and the script modifies the HA source code in various other ways too, to patch/remove things I don’t like). Pretty automated and hands off, unless the component json structure changes someday (unlikely but not impossible, seeing how trivially breaking changes are thrown around left and right in this project).
It would be nice if something like disable could be set:
default_config:
  exceptions:
    - cloud
discussed already to death. short answer: devs refuse to accept that (someone did that but it has been rejected from the release). If you want to exclude single integration you have to maintain the whole list on your own. This is devs stance
ā€œexceptionsā€ as suggested, should be the right way to do it. Basically this is a Nag Item and it’s right on top of all items.
Found a clean solution for this. It is to create a dummy custom component that overrides the default cloud integration.
  1. Go to /config/custom_components and create a folder called cloud
  2. Inside cloud create 2 files:
    Filename: __init__.py
"""Cloud."""
DOMAIN = "cloud"
def setup(hass, config):
    # Return boolean to indicate that initialization was successful.
    return True
Filename: manifest.json
  "domain": "cloud",
  "name": "Cloud",
  "codeowners": ["@yourName"],
  "version": "1.0"
You can do it manually or install custom repository in HACS:
https://github.com/benquan/cloud
I support the work by Nabu Casa and the services and support they offer, e.g. through the cloud integration. I am a paying customer.
That said, I maintain multiple HA instances and only one of those uses the cloud. Your solution is clean and will, other than the alternative workaround, introduce no unwanted side effects. Thank you! :tada:
Did this, now it just says ā€œLoadingā€¦ā€ under Home Assistant Cloud… Am I missing something?
I think this is intentional :).
Where is manifest.json located?
Manifest content changes with updates, how do you update it in the configuration?
Are you checking manually?
You’ll have to regularly check it. I hadn’t checked the manifest in a while and I was missing 2 newer (within last 6 months) items.
What I did was wrap it up in a configurable integration that just looks at default_configs current list of dependancies and loads all of them except the ones declared in my integrations list of exclusions. Should just automatically stay in sync.
This is the brilliant thing about Home Assistant. Sure the lead devs have some quite…strong…opinions that differ from most people (eg, we can’t have nested areas because the lead dev doesn’t see the need for them in his own flat), but at least we can hack in anything we can find time to hack in! It’s a wonderful project and I do really appreciate all the dedicated work the devs put in, and of course all the time the community puts in to partially undo some of that work.
EDIT: For the record, I pay for Nabu Casa to support HA, I just want to turn off the cloud integration because I use Cloudflared and have my instance behind a google login to keep out the riffraff. Shoutout to Cloudflare who I’ve been using extensively for years, all on the free tier. Most extensive free tier I’ve ever encountered, by far. Amazing.
It can be a pain on k8s… or we need to fork the repo/docker image, apply a patch to remove the cloud from default_config & republish a custom image :grimacing:
Try this
Home Assistant Cloud Hider
That just hides it, it does not disable the cloud integration like this post is asking for.
Under the circumstances, I’ll take it. Thanks @mindtricksdev!
EDIT - spoke too soon, it doesn’t appear to actually be working. @mindtricksdev, any additional steps needed after install, reboot, and cache clear?
