Hello, Is there a was to disable the lovelace component?
Other components such as mqtt and recorder you can simple just comment out or remove the relevent line in the configuration.yaml and the component is disabled, how can I do the same thing lovelace component?
If your goal is what mine was a while ago, of trying out some lovelace cards on your standard display, it doesnāt work that way. With lovelace you are either all in or all out.
Now, if youāve already got a frontend designed the way you like it, there are add-ons that will do a conversion for you to lovelace and are actually quite good at it. They actually keep your design pretty intact and just convert to the new display codes.
Iām trying to speed things up a little by turning off things that Iām not using in the configuration.yaml file - Iām using the old Polymer UI on all my devices.
If disabling Lovelace isnāt possible or causes issues then Iāll leave it on.
But just so you know - the whole thing is moving to Lovelace by default soonā¦
Thanks for letting me know - does that mean the old Polymer UI will stop working all together? Or that I just need go to āiā in the circle and click āset the old front end as the defaultā in future installs?
Iād like to stick to the old UI for now as found Lovelace doesnāt work that well for me on some Tablet devices, I know it is still considered āexperimentalā right now so issues are to be expected.
