How can i do this template to work
Hello
I would like to know if i can use this type of template format i tried different types of this and never worked, it’s supposed to return the state of the data_xxx sensor but i got an error formating:
'{{ states.sensor.data_{{ states.input_select.chooser.state }}.state }}'
This is my error message:
Error rendering template: TemplateSyntaxError: expected token ‘end of print statement’, got ‘{’
You can’t have a template inside a template. But you can do what you want this way:
"{% set e = 'sensor.data_' ~ states('input_select.chooser') %}{{ states(e) }}"
Thanks Will try it
Cheers
Worked Charm!! thanks
