How can I find my hardware on RPI3?
I have an RPI3, more or less. It has a different PCB but the specs are RPI3 and it swallowed the HA software I put on a micro SD and it works without problems. It has two USB, WiFi, LAN and HDMI. It also has a Z-wave (Sigma design), a 433 MHz (RFlink I think) and some LEDs mounted direct on the PCB.
Hardware info from the HA cli looks like this.
(Sorry, if I didn’t manage to paste the picture)
Anyone who can give advice how to find out the path to my hardware? Thanks in advance.
//Birger
What do you mean with “path to my hardware”?
Try
sudo lshw -short
I mean when I shall integrate for instance the Z-wave unit I need to tell the system where to find it. /dev/tty??? or something similar in the config file.
If you call the ha command before and after you plug the usb, you should see a new serial appear in the list. Something like:
~ $ hassio hw info
serial:
- /dev/ttyACM0
- /dev/ttyAMA0
- /dev/serial/by-id/usb-0658_0200-if00
- /dev/ttyUSB0
- /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
If they appear two new serial, they are the same device. If you can use the \dev\serial\by-id\XXXXX one, because this one always will be the same, no matter when you plug your USB or how many they are.
If I’m not wrong I yhink in your case you can use the /dev/serial/by-id/usb-0658_0200-if00
Thanks javicalle, I found the Z-wave
