How can I fix the network of haos?
My haos is installed using the vmware image and is bridged to the host. After the VMNet0 (the bridge interface) is removed and added again, I lose the ip previously assigned to the vm. Neither a restart of the host nor the cli command “net reload” helps. I see no commands to change the network config and I can not enter the shell env. How do I fix my network?
