I can restart the ESP from a button on my Home Assistant front-end.
Is there a way to force a restart without the button? Here is the script where I would like to reset the ESP when the OTA mode switch is detected as “off”. Alternately, can I force the ESP to go into deep sleep here?
# Script to test if the otamode switch is on or off
script:
- id: test_ota
mode: queued
then:
- delay: 10s
- logger.log: "Checking OTA Mode"
- if:
condition:
binary_sensor.is_on: otamode_button
then:
- logger.log: 'OTA Mode ON'
- deep_sleep.prevent: deep_sleep_handler
else:
- logger.log: 'OTA Mode OFF'
### This is where I would like to reset the ESP ###
- script.execute: test_ota
Well, a lot can be found in the documentation… I just looked at Button Component — ESPHome and TIL that a lambda wasn’t even necessary, you can also use:
- button.press: my_button
Given the fact that you are somewhat fluent in basic C++, looking at the .h files on the esphome github repo is the most complete documentation you can find
The Home Assistant and ESPHome documentation is quite thorough, but there is a problem. To find anything, you need to know what to look for. I probably spent two hours looking in the documentation and on the forums for ‘restart’ or ‘reboot’ or ‘reset’ before I asked the question.
I came back to this because I was pondering the answer. @jsuanet 's solution works and is correct, but I also looked at the c++ code for both button_restart and switch_restart and noticed that both call pretty well the same code, which you could put into a lambda
I have to learn to like Lambda’s. One of my long-term projects is to move the code for an Arduino project I wrote a couple of years ago. It is on a Wemos D1 and consists of two four-digit 14-segment LED displays. The data comes from Node Red over MQTT, but I have often wondered if I couldn’t send it using the API and have ESPHome on the Wemos D1.
It is not a need-to finish project, it’s supposed to be a learning experience. Maybe I’ll start by turning an LED on and off using Lambdas.
There is no need to turn a led on/off via a lambda as that functionality is built in. Lamda is really only for doing stuff that is not doable “natively” in esphome.
