How can I force custom cards to fill 100% of horizontal-stack height?
Hi, I have some cards in a default Masonry view that currently look like this (simplified for demonstration):
Here is the code:
type: horizontal-stack
cards:
  - type: button
  - type: button
  - type: custom:button-card
  - type: custom:vertical-stack-in-card
    cards:
The built-in cards, such as button, thermostat, etc. will all natively fill the entire height of the horizontal-stack rows, as demonstrated by the two button cards with differing contents. However the custom cards custom:button-card and custom:vertical-stack-in-card (and perhaps others) will not do this. I’ve been struggling to find a way to make their height behave similar to the built-in cards, such that they fill all the available height in the row.
I feel like there should be an easy way to do it without getting super granular with grids, but I’ve tried many combinations of css styles such as height:, display:, etc. and am failing to achieve this.
Could anyone recommend a solution? Thanks in advance.
P.S. Here’s the same, with an additional thermostat card added to exaggerate and demonstrate the issue a little more clearly.
cards:
  - type: button
  - type: button
  - type: thermostat
    entity: climate.living_room_thermostat
    cards:
I finally figured out card_mod, which solved my problem:
cards:
  - type: button
  - type: button
  - type: thermostat
    card_mod:
      style: |
        ha-card {
          height: 100%
    card_mod:
      style: |
        ha-card {
          height: 100%
    card_mod:
      style: |
        ha-card {
          height: 100%
    cards:
The card also has a styles section, so you can do that without using card_mod.
