I’d like to send a long message via smtp, how can I format the message into multiple lines? “\r\n” does not work.
Are you using the SMTP component? It should be trivial if you use HTML, and I suspect (but haven’t tried) that the same approach will work for the plain text body:
data_template:
message: >
This is your multi-line message
You just can't have a blank line
images:
- /home/pi/snapshot1.jpg
- /home/pi/snapshot2.jpg
When using message: > the first blank line ends the message.
@Tinkerer. Are you able to send images like shown above using the SMTP component?
Sorry for the off topic.
I don’t use the SMTP component
Hi there,
I’m sending Mails with Image and HTML with this script:
- service: notify.gmail_smtp
data_template:
title: 'DWD Wetterwarnung!'
message: ' '
images:
html: >
<hr>
{{ states.sensor.dwd_html.state }}
The file sensor reads a text file where the whole HTML is in one line and is generated from a python script.
how can I start new line in multiline message?? \n - does not work.
Also came here wondering how to insert a newline … \n or \\n etc?
update: I scoured around other threads and found that {{"\n"}} works for me. Example below will skip 2 lines.
- service: notify.SMTP
title: Alert!
message: {{ trigger.to_state.attributes.friendly_name }} alarm {{"\n\n"}}details: https://foo.com/whatever
