I’m trying to keep an eye on when people move into and out of range of my BLE and BT scanners, and I’d like to trigger a notify when the state of any of the “device_tracker” entries change.
Can anyone tell me what I need to do? Thanks!
I believe you want https://home-assistant.io/docs/configuration/events/#event-state_changed Do post any progress since I mean to test this soon myself
This is what I use to send me messages when the IOS app updates my location… It might get you started.
- alias: Notify iOS moving
platform: state
entity_id: device_tracker.ryans_iphone_app
service: notify.ios_ryans_iphone_app
data_template:
message: >
{{trigger.from_state}}
{{trigger.to_state}}
or publish to mqtt, then use a mqtt client on your phone
I would have thought the most explicit way to do this would be:
platform: event
event_type: state_changed
data_template:
message: >
{{state.ios_ryans_iphone_app.state.from_state}}
{{state.ios_ryans_iphone_app.state.to_state}}
Although the docs state ‘any state change will be announced on the event bus as a state_changed event containing the previous and the new state of an entity’ so the @rabittn approach works. If anyone can comment of the relative merits of the two approaches I would be grateful
Wouldn’t the Alert component cover this?
I haven’t used alert to verify but believe this is use case.
