I am trying to set up an inovelli red series switch which supports central scene. I am having trouble (because I dont know what exactly to expect). I copied the config files and edited the zwcfg***.xml file while homeassistant was stopped. When I restarted the changes stayed and I even got config options working which were not there originally. However the scenes don’t seem to be working or I don’t know where to look (or both). I tried looking in dev-tools/events and there does not seem to be a zwave.scene event.
I do have scenes being reported from the switch (this is from pressing the config button once):
2020-02-09 11:44:21.941 Detail, Node016, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x10, 0x05, 0x5b, 0x03, 0x14, 0x80, 0x03, 0x2a
2020-02-09 11:44:21.941 Info, Node016, Received Central Scene set from node 16: scene id=3 in 7680 seconds. Sending event notification.
2020-02-09 11:44:21.941 Warning, Node016, No ValueID created for Scene 3
and this is my zwcfg***.xml
<Node id="16" name="" location="" basic="4" generic="16" specific="1" roletype="5" devicetype="1793" nodetype="0" type="Binary Power Switch" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
<Manufacturer id="31e" name="Unknown: id=031e">
<Product type="2" id="1" name="Unknown: type=0002, id=0001" />
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="4" mapping="37">
<Instance index="1" />
</CommandClass>
<CommandClass id="34" name="COMMAND_CLASS_APPLICATION_STATUS" version="1" request_flags="4" innif="true">
</CommandClass>
<CommandClass id="37" name="COMMAND_CLASS_SWITCH_BINARY" version="1" request_flags="4" innif="true">
<Value type="bool" genre="user" instance="1" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
</CommandClass>
<CommandClass id="39" name="COMMAND_CLASS_SWITCH_ALL" version="1" request_flags="4">
<Value type="list" genre="system" instance="1" index="0" label="Switch All" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Disabled" value="0" />
<Item label="Off Enabled" value="1" />
<Item label="On Enabled" value="2" />
<Item label="On and Off Enabled" value="255" />
</Value>
</CommandClass>
<CommandClass id="50" name="COMMAND_CLASS_METER" version="3" request_flags="2" innif="true">
<Value type="decimal" genre="user" instance="1" index="0" label="Energy" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.116" />
<Value type="decimal" genre="user" instance="1" index="1" label="Previous Reading" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.104" />
<Value type="int" genre="user" instance="1" index="2" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="648" />
<Value type="decimal" genre="user" instance="1" index="8" label="Power" units="W" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="69.2" />
<Value type="bool" genre="user" instance="1" index="32" label="Exporting" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="button" genre="system" instance="1" index="33" label="Reset" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
</CommandClass>
<CommandClass id="90" name="COMMAND_CLASS_DEVICE_RESET_LOCALLY" version="1" request_flags="4" innif="true">
</CommandClass>
<CommandClass id="91" name="COMMAND_CLASS_CENTRAL_SCENE" version="1" request_flags="4" innif="true" scenecount="0">
<Value type="int" genre="system" instance="1" index="0" label="Scene Count" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="2" />
<Value type="int" genre="user" instance="1" index="1" label="Bottom Button Scene" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="3" />
<Value type="int" genre="user" instance="1" index="2" label="Top Button Scene" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="3" />
</CommandClass>
<CommandClass id="94" name="COMMAND_CLASS_ZWAVEPLUS_INFO" version="1" request_flags="4" innif="true">
<Value type="byte" genre="system" instance="1" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="1" />
<Value type="short" genre="system" instance="1" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="1793" />
<Value type="short" genre="system" instance="1" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="1793" />
</CommandClass>
<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1">
<Value type="list" genre="config" instance="1" index="1" label="Power On State" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="2" vindex="0" size="1">
<Help>When Power is restored Range: 0-2 Default: 0</Help>
<Item label="Previous" value="0" />
<Item label="On" value="1" />
<Item label="Off" value="2" />
</Value>
<Value type="list" genre="config" instance="1" index="2" label="Invert Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="1" vindex="0" size="1">
<Help>Inverts the orientation of the switch. Useful when the switch is installed upside down. Essentially up becomes down and down becomes up. Range: 0-1 Default: 0</Help>
<Item label="Enabled" value="1" />
</Value>
<Value type="short" genre="config" instance="1" index="3" label="Auto Off Timer" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="32767" value="0">
<Help>Automatically turns the switch off after this many seconds. When the switch is turned on a timer is started that is the duration of this setting. When the timer expires, the switch is turned off. Range: 0-32767 Default: 0</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="4" label="Association Behavior" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="15" value="15">
<Help>When should the switch send commands to associated devices? 01 - local 02 - 3way 03 - 3way & local 04 - z-wave hub 05 - z-wave hub & local 06 - z-wave hub & 3-way 07 - z-wave hub & local & 3way 08 - timer 09 - timer & local 10 - timer & 3-way 11 - timer & 3-way & local 12 - timer & z-wave hub 13 - timer & z-wave hub & local 14 - timer & z-wave hub & 3-way 15 - all Range: 0-15 Default: 15</Help>
</Value>
<Value type="short" genre="config" instance="1" index="5" label="LED Indicator Color" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="170">
<Help>This is the color of the LED strip. Range: 0 to 255 Default: 170</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="6" label="LED Indicator Intensity" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="10" value="5">
<Help>This is the intensity of the LED strip. Range: 0-10 Default: 5</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="7" label="LED Indicator Intensity (When Off)" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="10" value="1">
<Help>This is the intensity of the LED strip when the switch is off. This is useful for users to see the light switch location when the lights are off. Range: 0 - 10 Default: 0</Help>
</Value>
<Value type="int" genre="config" instance="1" index="8" label="LED Strip Effect" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="83823359" value="0">
<Help>Please see website for documentation. Range: 0-83823359 Default: 0</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="10" label="Active Power Alerts" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="100" value="10">
<Help>The power level change that will result in a new power report being sent. The value is a percentage of the previous report. 0 = disabled. Range: 0-100 Default: 10</Help>
</Value>
<Value type="short" genre="config" instance="1" index="11" label="Periodic Power + Energy Reports" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="32767" value="3600">
<Help>Time period between consecutive power & energy reports being sent (in seconds). The timer is reset after each report is sent. Range: 0 to 32767 Default: 3600</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="12" label="Energy Reports" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="100" value="10">
<Help>The energy level change that will result in a new energy report being sent. The value is a percentage of the previous report. Range: 0-100 Default: 10</Help>
</Value>
</CommandClass>
<CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="4" innif="true">
</CommandClass>
<CommandClass id="115" name="COMMAND_CLASS_POWERLEVEL" version="1" request_flags="4" innif="true">
<Value type="list" genre="system" instance="1" index="0" label="Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Normal" value="0" />
<Item label="-1dB" value="1" />
<Item label="-2dB" value="2" />
<Item label="-3dB" value="3" />
<Item label="-4dB" value="4" />
<Item label="-5dB" value="5" />
<Item label="-6dB" value="6" />
<Item label="-7dB" value="7" />
<Item label="-8dB" value="8" />
<Item label="-9dB" value="9" />
</Value>
<Value type="byte" genre="system" instance="1" index="1" label="Timeout" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="button" genre="system" instance="1" index="2" label="Set Powerlevel" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="byte" genre="system" instance="1" index="3" label="Test Node" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="list" genre="system" instance="1" index="4" label="Test Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
</Value>
<Value type="short" genre="system" instance="1" index="5" label="Frame Count" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="button" genre="system" instance="1" index="6" label="Test" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="button" genre="system" instance="1" index="7" label="Report" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="list" genre="system" instance="1" index="8" label="Test Status" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Failed" value="0" />
<Item label="Success" value="1" />
<Item label="In Progress" value="2" />
</Value>
<Value type="short" genre="system" instance="1" index="9" label="Acked Frames" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
</CommandClass>
<CommandClass id="117" name="COMMAND_CLASS_PROTECTION" version="1" request_flags="4" innif="true">
<Value type="list" genre="system" instance="1" index="0" label="Protection" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Unprotected" value="0" />
<Item label="Protection by Sequence" value="1" />
<Item label="No Operation Possible" value="2" />
</Value>
</CommandClass>
<CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" request_flags="4" innif="true">
<Associations num_groups="2">
<Group index="1" max_associations="5" label="Group 1" auto="true">
<Node id="1" />
</Group>
<Group index="2" max_associations="5" label="Group 2" auto="false" />
</Associations>
</CommandClass>
<CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="4" innif="true">
<Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3" />
<Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="6.04" />
<Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="1.09" />
</CommandClass>
</CommandClasses>
</Node>
