So I’m getting a lot of these “new devices discovered” notifications in Home Assistant, I have no idea why because there are no new devices. They keep coming again and again which is incredibly annoying.
I found an automation relying on the entity “persistent_notification.config_entry_discovery”. It is not in my list of entitites and when I use this code, HA doesn’t recognize it as a trigger:
alias: Remove new devices notification
description: ""
- platform: state
entity_id: persistent_notification.config_entry_discovery
to: notifying
- platform: homeassistant
event: start
condition: []
- service: persistent_notification.dismiss
notification_id: config_entry_discovery
This would now only work for me on HA starting but it would be great to have the system dismissing this message every time it appears (if I can’t tell HA to not even send it). Any ideas on how to solve this?
Top right in the integrations dashboard (aka the Devices & Services panel) there should be a new card showing which device was discovered. It will have the option to either install it or ignore it. If you select “ignore” then it should not notify you about this device again.
Oh, you’re right. The term “devices” was misleading, I didn’t think it was about integrations. There are some integrations I didn’t configure yet but wanted to do this at a later point. I will then click on “Ignore”.
I was convinced it would be some kind of mistake and reinterpreting a device as new that was already there for ages. The Alexa app does that sometimes. Hope that solves it but I guess it does, thank you!
