How can i get the current state of a device
Hey Guys, so I would like to know if it’s possible to get a customized response after requesting a link on Node-Red. A example:
After opening this link: http://192.168.3.123:1880/endpoint/living-lights/on, i’m able to turn on my lights. My idea now is to create a link like: http://192.168.3.123:1880/endpoint/living-lights/current-status, where i can get a response like:
The only thing that i need to know is how to get to this last picture where it shows { Current Lights State: ON}. I edited the Page Source to show that, so you guys can understand what i’m trying to get.
It’ possible to get that response, or anything similar, on Home Assistant? I would love to make it possible using Node-RED, but i’m open to any other solutions.
Look into the http request node, which should do it.
You might even be able to set the return field to a parsed JSON to just get “on” in the msg.payload.
What about the Home Assistant API?
Hey everyone, updating this topic. So to get the custom response is actually very simple, just use a “template function”, you can write up anything there basically. That together with the “current state”, is just what i was looking for.
Hi, could you please provide some details how to do this with Node-Red ? Are you using http request node or http in & http response nodes ?
Http In – Used to set the link that i’m accessing to make an action possible: :1880/light-1/on
Http Respose – Used to end the Request, otherwise it will be waiting forever to a respose, so just give it one, even if it’s not true.
Call Service – Do the action that i want when i access the link specified by Http In
Note that you can do different functions on Http In, if you’re planning to do it by your browser use GET.
