How can I get the translation of a sensor state?
I set up an automation to send me a notification whenever my vacuum cleaner changes its “error” state to one of the many pre-configured errors. I got the German translation running in Home Assistant, so I would have expected that message to be also in German. Instead my automation sends me the original English state which results in a language mix in my notification.This is what I have:
{{ states.sensor.vacuum_error.state }}}
Result: “none”
I also tried:
{{ state_attr('sensor.vacuum_error.state', 'friendly_name') }
Result: “None” (with a capital “N”).
German translation in Home Assistant is “Keine”, the entity shows these translated entries everywhere except in the YAML file. So is there a way to get this done without messing around too much and just taking the translations that are already in the system?
Try this
{{ states('sensor.vaccum_error') }}
you spelled vacuum wrong in your first example, and your second you spelled the entity_id wrong.
{{ states('sensor.vacuum_error') }}
{{ state_attr('sensor.vacuum_error', 'friendly_name') }}
Still “none” in English.
Sorry, my original template had the name of my entity in German, I wanted to use a more generic one for my example, “vaccum” was a typo. :sweat_smile:
Result: )>
Result: none
Result: Vacuum error *
  • name of the entity, not the state
This behaviour is expected. For example, if I want a message with someone’s home state by using the following code
Juhuu, Pedolsky ist wieder {{ states('person.pedolsky') }}!
the result is not „Juhuu, Pedolsky ist wieder zuhause!“ but „Juhuu, Pedolsky ist wieder home!“
You have to translate it for notifications in German.
And how do you do that? With if […] then for each state? :confused: I was hoping there would be an additional parameter to have the translation in the current language.
Just a few examples, this list is pretty long:
None if that exists in the backend. The frontend handles translations. That means you have to translate things for your notifications by hand.
I would use a dictionary in my notification. Here an example for translated weather conditions:
  - platform: state
    entity_id: sensor.zuhause_condition ## openweathermap integration
  - service: notify.gmail
      title: Das Wetter
      message: |
        {% set wetter = {'sunny': 'Sonnig',
                  'windy': 'Windig',
                  'windy-variant': 'Stürmisch',
                  'clear-night': 'Klare Nacht',
                  'partlycloudy': 'Tw. bewölkt',
                  'cloudy': 'Bewölkt',
                  'overcast': 'Bedeckt',
                  'fog': 'Neblig',
                  'hail': 'Hagelig',
                  'lightning': 'Gewittrig',
                  'lightning-rainy': '?',
                  'pouring': 'Starkregen',
                  'rainy': 'Regnerisch',
                  'snowy-rainy': 'Schneeregen',
                  'snowy': 'Schnee'} %}
         {% set bedingungen = trigger.to_state.state %}
         Heute wird es {{ wetter[bedingungen] if bedingungen in wetter.keys() else '?' }}
Okay, thank you, at least I know that now. Time for a little {% if %} … {% elif %} {% else %} I guess. :grinning_face_with_smiling_eyes: Starting to learn the syntax, maybe a good time to practice.
Thank you @pedolsky, might try that! :+1:
This is my solution now, based on your translation @pedolsky
service: notify.notify
  title: Gerätefehler
  message: >-
   Der Staubsauger hat ein Problem erkannt:
   {% set error_message = {'lidar_blocked': 'Lidar blockiert',
   'bumper_stuck': 'Stoßfänger klemmt',
   'wheels_suspended': 'Räder aufgehängt',
   'main_brush_jammed': 'Hauptbürste eingeklemmt',
    'side_brush_jammed': 'Seitenbürste eingeklemmt',
   'wheels_jammed': 'Räder klemmen',
   'robot_trapped': 'Roboter gefangen',
   'no_dustbin': 'Kein Mülleimer',
   'low_battery': 'Niedriger Batteriestatus',
   'charging_error': 'Ladefehler',
   'battery_error': 'Batteriefehler',
   'wall_sensor_dirty': 'Wandsensor verschmutzt',
   'robot_tilted': 'Roboter umgekippt',
    'side_brush_error': 'Fehler Seitenbürste',
   'fan_error': 'Lüfterfehler',
    'vertical_bumper_pressed': 'Vertikaler Stoßfänger gedrückt',
    'dock_locator_error': 'Roboter findet die Ladestation nicht',
    'return_to_dock_fail': 'Rückkehr zur Ladestation fehlgeschlagen',
    'nogo_zone_detected': 'Sperrzone erkannt',
   'vibrarise_jammed': 'VibraRise blockiert',
   'robot_on_carpet': 'Roboter auf Teppich',
   'filter_blocked': 'Filter verstopft',
   'invisible_wall_detected': 'Unsichtbare Wand erkannt',
   'cannot_cross_carpet': 'Teppich kann nicht überquert werden',
   'internal_error': 'Interner Fehler', '': '', '': ''} %}
   {% set error_state = states('sensor.vacuum_error') %}
   {% if error_state in error_message %} {{ error_message[error_state] }}
   {% else %} {{ error_state }}
   {% endif %}
alias: Benachrichtigung
I excluded several states from the trigger like “none”, “unknown” and “unavailable” since I got another automation for devices being offline. I also made sure that a status that I didn’t include would be displayed but in English. Just in case there is an update where the state names change or if I made a mistake.
I got all the states’ names from simply choosing them from the list and then checking the YAML file, one by one. I didn’t find an easier way. If there is one, let me know.
You could use state_translated() which gives you the state in the language to which HA is configured.
Which wasn’t available 9 months ago when the topic was created :slight_smile:
