Pico1965
(Pico1965)
June 29, 2023, 9:14am
1
In my automation i use:
- wait_for_trigger:
- platform: state
entity_id: switch.lastricosolare_pressostatorabboccovasche
to: "on"
for: "00:00:30"
timeout: "00:15:00"
continue_on_timeout: true
I need to handle differently the exit from the function for the satisfaction of the trigger or for the timeout.
Which is basically the behavior of the variable wait.completed unavailable in this scenario.
How can I do?
tom_l
June 29, 2023, 9:38am
2
- wait_for_trigger:
- platform: state
to: "on"
for: "00:00:30"
timeout: "00:15:00"
- if: # timeout occured
- "{{ wait.remaining == 0 }}"
then:
- service: # do something
else:
- service: # do something else in the triggered case
Or another test you could use:
- "{{ wait.trigger == none }}"
https://www.home-assistant.io/docs/scripts#wait-variable
There is a wait.completed member that tells you if it was successful.
- wait_template: "{{ is_state(entity_id,'on') }}"
timeout:
seconds: "{{ timeout_seconds * repeat.index }}"
- if:
- "{{wait.completed}}"
then:
- service: system_log.write
level: info
message: "turn_on {{entity_id}} {{target_value}}- success"
logger: service
- service: input_text.set_value
data_template:
entity_id: "{{ message_id }}"
value: "turn_on {{target_value}}- success"
tom_l
June 29, 2023, 11:43am
4
The docs say that variable,
Exists only after wait_template
So I did not include it because I was not sure if that also applies to a wait for trigger (instead of template).
